Question about AT&T TL96271 Black Cordless Phone
Answer incoming call and it disconnects 2-3 seconds after answering. How to repair or reset
3 Suggested Answers
afghandude01
  • 115 Answers
SOURCE: AT cordless phone answering system does not work
yeah first you record your voice then you gotta save it as your answering machine you probibly recorded your face but not save it so goodluck:) if doesn't work send me an email ill try to find more solutions...
Posted on Jun 06, 2010
  • 409 Answers
SOURCE: Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Posted on Jan 25, 2015
Jan 25, 2015 | AT&T Lands Phones
Answering macihne won't answer, disconnects after a few minutes
unplug your unit and allow it a few minutes to reset it's self. than call it using a cell phone and see if it does the same thing. If so check you menu option and make sure that the anserwing machine is not set up to only record for a certain period of time before disconnecting the call.
Aug 03, 2008 | Uniden TRU9485 Cordless Phone
Why does my device disconnect when receiving an incoming call?
You may be mispressing when you try to answer. Are you long pressing or short pressing to answer call? You should just tap to answer.
Mark
Motorola Support
Jul 02, 2014 | Motorola Mobility TZ710 Roadster 2
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
I have a 2 handset GE cordless 25932EE2. Both handsets work great individually, BUT when we answer an incoming call with one phone, we can't use both handsets at the same time (for the same call). In...
The problem may be due to both your handsets operating on the same channel. To fix, try pressing and releasing the "chan/delete" button on one of the headsets. This will move it to the next available channel.
Mar 08, 2011 | GE 25932 Cordless Phone
I just bought a x4270 lexmark.i do not see in the maual set up for smart ring,another term is short ring and ido have a answering machine set up aswell.im wondering if i can even use this unit.any answers?
Yes, you can.
You have to connect the answering machine to the X4270 like this
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/basics.html#wp633882
and set it to answer before the X4270 does. Say, 4 rings for the answering machine and 5 for the X4270.
The X4270 will monitor the few first seconds of the call anyway, and if it detects the whistle of an incoming fax, it will disconnect the answering machine and receive the fax.
With most answering machines, disconnecting while the greeting message is still playing will not be considered a call.
Oct 28, 2009 | Lexmark X4270 All-In-One InkJet Printer
My GE #28223 phone will not let me answer incoming calls at times
This happens when the base somehow gets de-registered from the handset. There are two ways to solve this.
Disconnect the base from the electrical outlet for about 5 seconds, then plug it back in.
The other way to solve it is to re-register the phone with the base. Consult your user manual to follow the process. to do this.
Feb 14, 2009 | Uniden Cordless Phone
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Apr 01, 2008 | Uniden TRU9488 Phone
GE Digital Messaging System Model # 29875GE1-B
If I am away from my machine and want to call my answering machine and hear the messages what do I do. Lost my manual.
Jan 07, 2008 | GE 29878GE1 Digital Answering Machine
AT&T TL96271 Black Cordless Phone Logo
44 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
