I need to know if u can sell me the top cap 4 model # 54255 sprinkler 4" pop-up the tops keep breaking
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
I will sell you some info,,go to where you bought it,what makes you think we sell things??
Posted on Apr 24, 2015
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
Sprinkler will not pop up
Sounds like "Sure pop" was misleading. Try unscrewing the top or entire sprinkler then the top remove the spray nozzle to access the spring. Stretch it out longer and re-assemble the sprinkler screw it back in place with the spray notches on nozzle facing are you want covered. This should solve the problem if not, replace the pop-up.
Jul 15, 2013 | Rainbird Sure Pop 600 Series 2-1/2" Pop Up...
My rain bird 1800 head keeps leaking how to fix it
if this is an older sprinkler ,it may just be worn.usually the leak is around the white plastic surrounding the popup shaft.in this event the cap needs to be replaced.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Nov 08, 2010 | Intermatic R8806P101C -...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Agitator: bottom moves, top does not
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore model 80 topload waher: does the agitator cap just pull off? don't want to break it.
cap pops off,remove pull up cover and find 7/16 bolt holding agitator to trans.
Sep 12, 2009 | Kenmore 22422 Top Load Washer
Source code for stack using arrays in c++
stack in c using arrays
/* Program of stack using array*/
#include
Dec 05, 2008 | Computers & Internet
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
