Question about Toro TimeCutter MX4260 - 23HP 42 Zero Turn Mower
The motor won't shut off using the ignition, the electric parking brake won't release, none of the safety switches are functioning. It starts and the engine runs great.
2 Suggested Answers
  • 2471 Answers
SOURCE:
Sounds like the safety switch is bad or needs resetting. I had a lawn tractor that did that and I disconnected the safety switch. I know you should not do this but I did not want to put more money into this machine. It does work ok without it.
Posted on Feb 18, 2018
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
Mower shuts off as soon as you release parking brake and in park will shut off if you turn blade on
You most likely have a safety switch issue, try un-plugging the switch in question and holding the wire connectors together with a small vise grip and do a test to see if it will run. If it stays running, then replace the switch in question before using your machine.
Oct 08, 2016 | Vanguard 48" Great Dane Zero Turn Lawn...
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 21, 2014 | Kenmore 659 Electric Dryer
Husqvarna zth quits when releasing parking brake
check the safety switches on each lever
Jul 09, 2012 | Garden
Ignition switch won't release key when it is put in park. But when I removed switch and key tumbler, the key tumbler/cylinder releases key. Why won't the key release when it is in park?
Most newer models have a safety feature called
shift interlock. This prevents the key from being turned back
to the lock position if you forget to place the gear selector in park.
Depending on the model,
If it uses a cable, it may be sticking or needs adjusting.
If it uses an electrical solenoid. may be blown fuse or park switch.
Tap, shake, and pull up on the shifter and make sure it's in park.
May 25, 2012 | 1993 Jeep Grand Cherokee
Sometimes it wont come out of park
check the neutral safety switch,, or what some call the start safety switch,, look up at the top of the brake pedal, push the brake in, there is a switch up there that controls shifting, if its a combined switch it also controls the brake lights,, remove the switch and test it with a meter,, when depressed in you should have continuity , when released none, if not, your switch is bad, replace it
Sep 09, 2011 | 1993 Pontiac Bonneville
Cannot get to work with manual transmission please help with any ideas?
There are several steps necessary for the unit to function with manual transmission. Now,the unit comes programmed for manual transmission out of the box. Next, the neutral safety wire (thin black with white stripe) MUST be connected to the parking brake wire. Also, the tachometer wire MUST be connected. Check the neutral safety switch as well. Did you install a clutch bypass? All that is left is the system setup for remote start: Start the vehicle with the key,make sure all doors are closed, put the vehicle in neutral, press on the brake, apply parking brake, release brake, within 15 seconds remote start the vehicle, the parking lights will flash to confirm the remote start activation, turn the ignition off ( the vehicle should stay running.Exit the vehicle. Arm the alarm ( the vehicle should shut off). You are now able to operate the remote start. This process must be done each time you exit for the remote starter to function on a manual transmission vehicle. Don't worry ,you'll get used to it.
Oct 12, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Toro TimeCutter MX4260 - 23HP 42 Zero Turn Mower Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
