Question about Whirlpool LTE5243DQ Combination Washer/Electric Dryer
How to open the front panel - Whirlpool LTE5243DQ Combination Washer/Electric Dryer
  • Whirlpool Master
  • 5,323 Answers
See the pics I beleive its the same
Posted on May 16, 2015
How do you open the front panel to check the brushes
  • Open the door
  • Pull out the mains plug
  • Remove the metal ring around the door opening seal (apply pointed pliers to stretch the spring beneath the door opening)
  • Push back the seal from the front panel
  • Loosen the two door opener screws
  • Remove the plinth
  • Remove the two outer upper screws behind the plinth
  • Remove the bolt right underneath the door opening while supporting the front panel
  • Gently lower the front panel and take it away
If the brushes are all right, then probably the electronic is defective.
Check for our repair service at www.youfixit.eu.
Jun 30, 2014 | Miele Novotronic Premier 500 Front Load...
How do I take the cabinet off a GE gas dryer model # DHDSR46GE1WW to check inside?
The following website may be helpful:
https://www.partselect.ca/Models/DHDSR46GE1WW/Instructions/?InstructionID=21302
This was extracted from the website:
Remove the two screws at the front above the drum opening (with the dryer door open). The top panel then lifts off. I removed the screw at each side that holds the front panel to the side panels, tilted the front panel forward, which disengages the front of the drum from the front drum glide bearing. I then lifted the front panel slightly, unhooking the bottom of the panel from the dryer base, and swung the front panel aside.
Oct 10, 2017 | Dryers
How do I get the top off
The front panel needs to be removed first before the top panel can be lifted. This is due to the top panel hold down brackets hidden behind the front panel posts. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order. Click on the link below for more detailed disassembly procedure.
Removing the Front and Top Panels of Maytag Sloped-Front Dryers
Mar 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How do I remove the top and front panels of my Maytag MDG7600AWW dryer?
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 06, 2010 | Maytag MDG7600AW Gas Dryer
How to remove top of Maytag dryer
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
How do you remove the front panel on LG model # DLG0452W . I want to replace the igniter glow.
Disconnect the washer from the power source. Use a putty knife blade to release the locks of the top panel. Insert the putty knife blade in the seam between the top panel and the front panel about 2 3/4" from the edges. Push until the locks are released and lift the top panel.
Open the door and remove the 2 screws from the bottom of the door opening. Remove the 2 screws from the upper side of the front panel and pull the front panel out. Disconnect the door switch connector and remove the front panel completely.
Feb 12, 2010 | Washing Machines
How do i take the face off the pioneer deh p7000bt
Press the open button, so the face opens downwards; hold the left side of the panel and pull it gently outwards...
Source of instructions
Sep 27, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
Need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Mar 01, 2009 | GE DVLR223 Dryers
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Feb 21, 2009 | 1996 Ford Thunderbird LX
Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
161 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
