My cd changer is not working, I think the gears are not set right. do you have that timing set-up information
Cd got stuck, openented it up and moved some of the gears around (Position) trying to get it to open and close correctly
  • 275 Answers
SOURCE: CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Posted on Sep 15, 2006
techman
  • 3130 Answers
SOURCE: CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Posted on Jul 15, 2007
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
Siliconchip
  • 52 Answers
SOURCE: bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Posted on Jan 03, 2008
SOURCE: cd door won't open
I just bought the same system a week ago and my stereo door is completely broke and the cd peice doesn't eject
Posted on Mar 22, 2008
Disc Compartment Stuck
There are a few reasons for this, the gears are seized, the timing gear is out of sync, or the miniture loading belt has broken or stretched.
Jun 24, 2012 | RCA RP8065 5-Disc CD Changer
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
Error 01 the magazine does not eject
A lot of times there is a gear inside of the changer that gets jammed. If you can, remove the top cover of the changer. On the changer mechanism (it will be on the right side of the changer) there will be a large gear (probably black) with an arm attached to it. Use a flat blade screw driver or something like that and turn the gear counterclockwise until the tray is back in magazine. You should then be able to put the changer back together and it will probably work fine.
Nov 02, 2011 | Alpine CHM-S620 6-Disc CD Changer
Hi jag xjs 1993 cd cassette wont eject as no 6 stuck in any hints on how to eject the casestte?
you would have to take the to off of the changer. If you can do that, on top of the cd mechanism is a large gear which slides the trays in and out of the magazine, If you can, move the gear so the tray slides back into the magazine. The changer will probably work once that gear is freed.
Jul 22, 2011 | Car Audio & Video
I have a 2002 neon everything. I was recently driving and I noticed all the lights on my factory cd changer were blinking, no CDs would eject, is there anything I could be doing to troubleshoot or fix this...
Unfortunately, my experience with the factory multi disk changer is no. Sometimes it is a matter of disconnecting and reconnecting to get it to a point where the system will eject the CD's. The problem actually appears to be a dust build up in the changer itself over time. It was only designed to work for about 5 years so you are well beyond that. My son was able to remove it and open it up and clean it out and got one to work for about 2 more years but in the end he ended up replacing it. Typically the gears that work the disk ladder inside jam up and cause it to fault out as the drive motor gets weak over time. In most cases to get your disk back you are going to have to open it up and manually cycle to each disk and remove it. Sorry, no really good news.
May 14, 2011 | 2002 Dodge Neon
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
RE-TIMING OF DECK MECHANISM
Hi there a pain, the 3 black gears/guides on the 3 poles slip there is a mod kit see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
works in 9 out of 10 cases.
Regards
Mark
Feb 19, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Mar 27, 2007 | Sony CDP-CX400 400-Disc CD Changer
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
65 people viewed this question
 Grubhead
Grubhead
