Question about Measuring Tools & Sensors
How to connect focus axr sd smart meter - Measuring Tools & Sensors
Why has my 3 week old smart meter screen gone black,it will come on for about 60 seconds when we press the button and just says "connecting to smart meter
report this to you supplier they will send out a replacement, it could be its not charging and the screen goes off and will restart. if you don't have it on charge leave it plugged in charging, i leave mine plugged in charge all the time. cost around 2p a year can live with that. but if its on charge and still not working as it should report to your supplier, hope this help
Jun 28, 2017 | Smart Computers & Internet
My 2003 Ford Focus would not accelerate, and kept dying on me, now wont start, do you know what could be wrong?
A strong possibility of a defective Throttle Positioning Sensor (TPS)...It can be tested with a volt meter...TPS is located on the throttle body (see diagram below) & has a three pin connector with following wire colors; Brown (ground)...Yellow (+5 volts)...And White (TPS output)...Set meter to 5 volt dc...Push point,of safety pins into the Yellow and Brown wire at rear of connector...Do not disconnect connector...connect + lead to Yellow pin and - lead to Brown pin...Turn key on...Meter must read at least .08 volts...Open throttle full...Meter must read at least 4 volts...If not TPS is defective...Send results...NOTE>>>Diagram is based on a 2.0L Single Overhead Cam Engine, if your vehicle is different let me know...saailer
c39c38e9-1e2b-4d1e-b695-576183306462.jpgCost about $30
Jun 25, 2014 | 2003 Ford Focus
Connection tv
The regular RCA cable would do the job
Dec 29, 2013 | Toshiba SD-K620 DVD Player
Hello again, andthanks for your help. i have found a samsung SD card adapter in the box my phone came in. can i put my sim card in this and then this in the Sd card slot on my tablet.
the SIM is a smart card amd has a special slot for it in your cellphone.
It does not fit anywhere else.
An SD card adapter is (of course) only for SD cards.
If you want to see what is on your SIM card, connect your phone to your tablet with a USB cable.
Feb 24, 2013 | Cell Phones
Is it possible to obtain a meter reading from a Ricoh SP3410DN which is only connected via USB? Can it be printed? The ethernet connection is not in use so Smart Organising Monitor cannot be used.
Print properties, advanced options tab, smart organizing monitor button, user tools tab, print a configuration page. Counter is in the bottom left of the printed page
Jan 25, 2011 | Office Equipment & Supplies
Sony tv kp51ws500. 3 colour off centered.2 conv.ics replaced componant and voltages ckecks ok.yet convergence doesnt adjust.magic focus doesnt adjust colour. whats the solution.
perfect focus is what this uses-magic focus is what it is called in the Hitachi sets.
If it is KP51ws500 did you check the two 5 amp pico fuses on the other board---the power supply board?
let me know what you find and I will help you--I have fixed hundreds of these sets.
SD TECH
Dec 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
AIWA Stereo AV Receiver AXR-005
did you ever get an answer?? i'm having the same issue
Nov 08, 2008 | Aiwa AV-D58 Receiver
Measuring Tools & Sensors Logo
167 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
