Question about LucasArts Entertainment Company Lego Star Wars Ii: The Original Trilogy for DS
How do I fix error 4001 (please put in original disk)(original disk is already in)?
  • 5,631 Answers
If disk is original, return it from where you got it, because it's defective and it is not recognized by reader.
Posted on Apr 24, 2015
  • Anonymous Apr 24, 2015
    I have used it on other computers and it has worked this is the first time this has come up.
I have a Canon ADY0002 plotter with an E146-4001 error. Can you help?
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
Jul 28, 2011 | Office Equipment & Supplies
I need the firmware of the Polaroid PRDBT-4001 CD-RW Burner, I do not know the official websate of the manufacturer of this unit. Ing. Humberto N. Rdguez
http://www.polaroidmemory.com/support/support_download.htm
If you have the Polaroid Burnmax32, firmware version 08, and a sticker on the top of drive says BCE3212IM, there is a firmware update, version .008G, you can try. I had the same problem of the drive just disappearing, and now it's fixed. You can get the update from this chinese webpage, so you may want to use a translator like altavista's babelfish to read most of the page:
http://www.teclast.com/topic.php?channelID=69&topicID=141
Just look for the firmware that's version "v.008G"
To use this update, you absolutely should know how to use mtkflash in dos from a startup disk. But this update package also comes with a bat file, "up.bat", that runs mtkflash for you, so it's a breeze. But FIRST, you have to use mtkflash manually to make a backup of your existing 08 firmware in case something goes wrong so you can always put back the original firmware. Good Luck.
Apr 27, 2011 | Polaroid PRDBT-4001 CD-RW Burner
HOw to disable the paragon 4001
4001 series timer is Paragon 120V mechanical timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
1) To disable the timer, turn off circuit breaker and take wires off of the terminals. Put wire nut over each wire, and circuit will no longer operate.
2) If you want the circuit to operate without timer, then take wires off terminals. Twist black wires together and cover with wire nut. Twist white wires together and cover with wire nut.
3) Buy Intermatic T-101 timer to replace Paragon 4001 timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Sep 13, 2009 | Paragon 4001-00 24-hr Timer Control 120v...
Fixed unplayable disk error but now i get told to put disk in an xbox 360 console
Lol then no sir you did not fix it. Sorry.
"to play this disc, please put it in an Xbox360" error is caused by one of two things.
1) Dead/Dying laser- Replace it or try to adjust the variable resistor on the laser lens. (USE a micrometer on the 20k setting and a 1.8mm flathead)
2) Incorrect drive key- If you "fixed" your initial problem by buying a new dvd drive, and putting it into the console. You no longer have the correct dvd key to match the Xbox360 motherboard. IF both drives are the same brand. You can simply remove the green pcb from the old drive and put it into the new drive. (be CAREFUL with the ribbons!!) If you did purchase a new drive, and already threw away the old drive, you're screwed the Xbox will NEVER play a game again, unless you download it from Xbox Live.
Aug 15, 2009 | Microsoft Xbox 360 Console
Hardware can I put into a ToshibaSatellite 2455-S3001 ?
hi, unfortunately the design of the laptop's are very rigid and only allow the extension of the ram memory and hard disk capacity up to twice the disk that originally brought.
Jun 08, 2009 | Toshiba Satellite M40-S417TD Notebook
Error connecting
This is an issue with Nova Worlds servers, and unfortuantly you will have to wait until they fix that issue. Usually they do maintenance on Friday-Saturdays.
https://www.novaworld.com/Error.aspx?aspxerrorpath=/NWCommunities/topic.aspx
May 24, 2009 | NovaLogic Joint Ops: Combined Arms for...
My Xbox 360 can't read any disks.
hey i had this problem and taking my hardrive out, starting a game, and then shutting it off and putting my hardrive back in worked!
Mar 30, 2009 | Microsoft Xbox 360 Console
Sims life stories won't run
try go to www.megagames.com and go to pc fixes on the side bar. Then you just simply fin your game, game fixes and download a no-cd crack. After this you put the cracked exe file in the folder where youre install files and other files for the game is( example. C:programfiles/EA GAMES/ sims life stories/ ) you might want to save your original exe file in another folder so if the crack don't work you have the original exe, but just put the crack in the folder where youre game is =)
Jan 06, 2009 | Electronic Arts The Sims: Life Stories for...
Help please
hi first thing to do - update your firmwear http://www.cd3o.com/support then look in troubleshooting: http://www.cd3o.com/support/doc/Product_Manual.pdf im sure it will do the work good luck
May 05, 2006 | Cd3o C200 Wireless Network MP3...
LucasArts Entertainment Company Lego Star Wars Ii: The Original Trilogy for DS Logo
781 people viewed this question
Top LucasArts Entertainment Company Video Game Consoles & Games Experts
seanwalters1
Level 1 Expert
EnergeeUK
Level 1 Expert
Are you a LucasArts Entertainment Company Video Game Console and Game Expert? Answer questions, earn points and help others
