Question about Sony SDM-HS73P 17" LCD Monitor
What do i do when the dialogue box reads 'cable disconnected burn in mode'
Screen turns white after non use
  • Sony Master
  • 5,631 Answers
Get monitor out of burn in mode by unplugging the power to monitor then while holding down the power button on monitor plugged in the power cord to the monitor all while it is connected to a running computer. Turn the monitor off with the power button. When press the power again the burn in mode should be gone and the monitor should display the computer
Posted on Apr 24, 2015
My screen is saying burn in and keep switching colours all the time.(white,red,green,blue.
You may need to send in unit for service because your unit is unable to go to sleep mode when the signal cable is disconnected or the PC is turned off. Please call ViewSonic Customer Care for support.
Although this will not hurt the monitor, you just need to apply an active video signal to get a display correctly. However, it will not work as expected to go into sleep mode. You'll need to call ViewSonic Customer Care to get this taken care of.
May 09, 2014 | ViewSonic VA721 17" LCD Monitor
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
Ps3 80 gig pixalated on hd screen beond reading.
That is usually a problem with the motherboard graphics chip. You would need a motherboard gpu reflow. To check this, connect a non dhmi cable to see if the same problem occurs,
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
The screen will not turn on
Yes these Monitors encounter problems:
1. Bad Inverter
2. Burned out Backlight
3. Power supply issues
Sounds like your inverter board is bad and backlight will probably follow!
Nov 25, 2007 | Gateway FPD1810 18.1" LCD Monitor
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
380 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
