Question about Kenmore Dryers
Can i use my old 4 prong cord on my new dryer ?
    Top Expert:
  • 2,899 Answers
As long as you are plugging the same old cord into the same wall plug as before and the new dryer requires the same four pronged connector.
And if they both are 220VAC plugs.
I would buy a new cord, depending on how many years and how much abuse the old cord had. And who used the old cord.
Hope this helps.
Posted on Apr 24, 2015
  • Kenmore Master
  • 5,631 Answers
Check you cord if it should resist the amperage of your dryer. and have security plugs. Else, no problem
Are all dryer power cords the same except for being either 3 or 4 prong?
They are universal. Just hook the new up the same way the old one was, assuming it was wired correctly.
Feb 02, 2016 | Samsung Dryers
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer has a 3 pronged connector but the new house has a 4 pronged receptical. I took the old cord off and purchased an new 4 pronged cord. My problem is that the dryer has three connecting points for...
to a screw on the rear of cabinet there may already be a wire connected there if so remove it and tape it off install green ground wire there
Aug 05, 2008 | Dryers
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
GE electric dyer cord
You must change the cord on the dryer. New house constuction electrical code requires a 4 prong receptical (double grounded).
You can buy a cord at Lowes, Home depo, Sears, etc. When you install the new cord there is a brass strap from the neutral post to the dryer cabinet that you must remove.The extra green wire in the cord connects to the cabinet. Your old cord probably won't be color coded, but the new one will be. Red is hot, goes on the end post, (doesn't matter whichn end). white is neutral and goes on the middle post. black is hot & goes on the other end post.& green goes to the cabinet.
Nov 12, 2007 | Dryers
Dryers Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
