Question about Mitsubishi Televison & Video
Mitsubishi_dm_board_repair WD 73737 Blinking green light, plan to replace the undersized capacitors and the thermistor as I read were recommended.
  • 1153 Answers
SOURCE: DM Board WS48511 Green Blinking Light
If you do not already know where your problem is then Check for 12 volts DC (AC-off detect) at pin 3 of PC9A21, if missing replace PC9A21 part # 268P058020 on the Power PCB. LED does not blink at plug in. Check for 5-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P089010 on the Control PCB. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 4.7 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D587002 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 935C978002 . Also if you can do a self diagnosis test by pressing the device and menu for 5 sec on panel of set and read the error codes.
Posted on Dec 10, 2007
SOURCE: Blinking green light stays on and TV won't turn on.
Green Blinking Light - Order a DM Modual from Mitsubishi. Read the plug labels when reinstalling.
Posted on Dec 14, 2007
  • 5 Answers
SOURCE: mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Posted on Jun 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: Mitsubishi WS-55613 Blinking green light. I have
Hi
Thanks for using FixYa. The green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating with each other.
This issue is due to 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors). These capacitors are apparently small as compared to load they get & due to this they will eventually fail (usually after about 3 years). Or else they fail when there are voltage fluctuations in the circuit above 16 volts. It is recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur. You’ll need to take the back off the TV apart in order to remove the faulty DM module. You’ll need to desolder the old capacitors on DM board and install. Also check the grounding straps which are essential to the proper functioning of the DM module.
After replacing several bad capacitors (you can get replacement capacitors from Mouser electronics on line by the way.. be sure to order the same capacitance values and same or higher voltage rating and be sure they are rated for 105 degrees C.) I still had the dreaded G.L.O.D. Note that the first time I plugged it in after taking it apart the G.L.O.D was not there and it powered up normally. But when I had to unplug the set too fully re assemble it, it came back.
The issue is caused by both the FMT board (formatter) and the DM (Digital Module) board’s microprocessors tying to establish communications with each other. Somehow a race condition gets started with each thought that the other board needs to be reset and then starting the boot process over again. You need to interrupt this cycle with a switch. Buy a DPDT switch from radio shack (or Mouser Elect) and again take apart your electrical chassis (If you have it apart replacing bad caps you might as well add the switch or you may end up having to disassemble the whole thing again.) On the FMT board along the top edge near the input connector side of the chassis there is a four wire connector labeled “FC”. It has two black wires and 1 orange and one Brown wire. Leave the black wires connected and cut the orange and brown ones about an inch from the connector. Solder four 12 inch wires onto the ends (one on the source side brown, source side orange and one on the connector side brown and connector side orange) use heat shrink tubing to cover the solder connection points. (If you can’t get tubing, then electrical tape will do, but make sure the joints can’t short out to each other or the electrical chassis.) Now take the brown and orange wires from the connector side and solder those to the middle two terminals of the DPDT switch (one on each side not both to both terminals) Then pick one side of the outside terminals of the switch and solder the source side brown and orange wires to the terminal across from the same color (brown across from brown and orange across from orange) See the diagram below. The idea is to connect the wires normally when the switch is closed and break the connection when the switch is thrown the other way. Before soldering the wires to the switch add a piece of heat shrink tubing to wire so that you can cover the solder point up after it is assembled.
Now re-assemble the electrical chassis and route the switch/wires outside the chassis (I snipped a hole along the edge of the top fan shield to get the wires out.) and put it back in the TV. You need to also get the switch to the outside of the TV somehow (I drilled a ½ inch hole in the plastic cover to snake the switch through but you can do it however you like)
Here is how to use it- From a fresh plug in- throw the switch to the OPEN position (the wires are not connected) plug in the TV, the green LED should stop blinking after 60 secs like it is supposed to. Once it stops, flip the switch the other way so the wires are connecting. Hit the power button. The TV should turn on- you’re done! Yeah!
From a plugged in, hmmm my power must have gone out, state. Assuming you have the GLOD, flip the switch to the open position, hit the reset button on the front of the TV, wait for the blinking to stop, flip the switch back closed and turn the TV on normally… Again you are done…
Note that the first time you turn on the TV you may have to flip the switch the other way (if the TV won’t turn on even without a blinking LED) this means that the switch was open and you need to have it closed to get it to work. If you tried turning on the TV with the switch open, start over by following the reset button procedure above.
Note this is much easier to do than it sounds. Also note that it helps if you have the repair manual. This is nice to have because it has a wiring interconnect diagram also which details all the connector placements
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 19, 2009
SD Tech
  • 14553 Answers
SOURCE: Help needed please. Mitsubishi ws-65909 I have
you have one of two problems :
1.) The DM is defective and needs to be sent out for rebuild---there are several places including a company called PTS Electronics who do this.
2.) Something that is often overlooked and is simple to try is:
Remove front speaker grill and inspection plate behind it; Locate the two sets of wires coming from the front keyboard controls and follow them to the right and UNPLUG BOTH PLUGS.
This takes the keyboard and "reset" button out of the circuit; sometimes it is not the DM but a defective reset button.
The set can still be turned on with the remote; if it now works you have two choices: use the remote and leave the keyboard disconnected OR remove the entire screen with the keyboard and replace the reset micro switch--you can also just unsolder and remove it.
I have seen people ASSUME the DM is the problem and it may but this is a easy thing to try.
If you found my solution helpful please rate this solution with a "very helpful" rating as I do this here for free.
If you have any questions feel free to respond to this posting with a COMMENT.
REGARDS, SD TECH
Posted on Aug 10, 2010
Mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
We lost power the other night. Now I have a continuous green blinking light and it won't turn on. I have tried everything the manual says.
Try Going To The Mitsubishi Web Site. Downloading The Mitsubishi Service Manuals If You Don't Already Have It. It Will recommend The parts You Need To ordering. Circuit board photos are also shown which provide a visual reference during the repair process.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
Sep 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi wd-62528 has a constant rapid green blinking light on timer and wont go out. had lamp replaced and reset but wont even come on.
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Have you tried the reset button on the front of the tv, on the far left I believe? That probably won't solve your issue since this has been an infamous problem for Mitsubishi.
If the reset button doesn't work the most probable fix are the (12) 1000uF capacitors (4 on each board) on the Power Supply, FMT board and the DM board. There are several other replies from reputable repair people on this site for this problem on the wd-xx525 series.
You probably just need to replace the DM capacitors. You can get the V26 DM repair kit from www.tvrepairworld.com which has the capacitors and the Cd with instructions
Jan 29, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light for Model WD-52825. What
The usual cause is due to the DM not booting up due to failed capacitors. You can get the V26 DM repair kit at www.tvrepairworld.com which contains the replacement capacitors and the CD with detailed instructions.
Dec 20, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Mits 525 started blinkng green standby light today makes a muffled sound as it beeps. wont turn on just beeps.just under 4 yrs old. have replaced bulb 3 times. reading some of these posts seems like...
The first generation mitsubishi V26 chassis which is what your model is has a bad habit of failing capacitors. The steady blinking green power light is related to the DM not completeing the boot up sequence. You can get the V26 DM repair kit at the following link which contains the replacemnent caps that are prone to fail and has the CD with step by step instructions on how to duisassemble the cjassis and replace the caps. Its very inexspensive and will usually repair that issue. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Timer light on Mitsubishi WD62725
get a ohm meter and check all fuses ,and diodes they should all read 0. the ones do read something are bad replace them that means solder them out and back in
Mar 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi HDTV
Press and hold menu button for 8 sec, then unplug for 1 minute. Plug back in and 1 minute later it will pop up for you.
Jan 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
