Question about Rainbird Rain-bird Esp-40sat Lawn Sprinkler Irrigation Controller 40 Stationcam-link
Zone 5 & 6 no longer show up on my control board and do not provide water to those sections of lawn.
  • 3,287 Answers
Which brand / model sprinkler control do you have?
Posted on Apr 24, 2015
Why doesn't it connect to sensors?
From your description, it seems that the transmitter section of SC-001 is working properly. What you have done to reinstall the system may not be thorough. And it is unclear whether the control panel is not responding to keychain transmitter or sensor or both.
I assume that you have followed the instructions in the manual to clear the zones. Simply unplugging the AC power and removing battery will not clear the zones. Note that sensors can be programmed into zones 1 to 4. Keychain transmitter can be programmed into zone 5 only. There is no LED indication for zone 5.
Secondly, follow the instructions to program the sensor or keychain transmitter to the control panel. The corresponding zone LED will be flashing during programming. There is sound indication as well for successful programming of the device.
If you do not program the sensor or keychain transmitter to the control panel after clearing the zones, the control panel will no longer respond to the device.
The dialer and siren is not cleared on the control panel. They can be cleared only from the dialer or siren itself.
Dec 11, 2015 | Skylink Group Skylink Sc-100 Security...
The inside refrigerator temperature display and water filter replacement percentage display are no longer working. Can I replace a fuse or do I need to call repairman?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, which is located on the upper inside wall of your fresh food section. So, I can only be general.
There are small lights on the electrical control board. These lights burn out. The entire board has to be replace. You may check for loose connections or burned wires first.
A service call of this nature is about $400.00-$500.00.
Mar 25, 2015 | Refrigerators
My Kenmore bottom freezer model 65619 display panel is dark except for one little bar, not sure if the fridge is working
Hello Monique;
The number that you provided is a common owners manual number, which is common to several units.
Your model number is located on a label on the side wall of your fresh food section.
On your electrical control board there are tiny lights. Although your unit is working the lights have burned out.
This board needs to be replaced. It is about $127.00.
Go into the following web site and put in your model number. You will see diagrams including the board. You may be able to purchase the board for less, just search the board part number. Water Filters Lawn Garden Appliance Parts
Mar 07, 2015 | Kenmore Refrigerators
My toro greens keeper controller for my water system will not start up any of the zones? what might be the problem?
ck zone programming , even if it was working i had one on the course that seemd to have a mind of it's own and allways reset it's self to o:oo for the time of day
Sep 30, 2014 | Garden
How do you change the zoned sections on the control panel/remote
you need to do the programming of the Zones with in the first 5 min after powering up tghe unit threw the wall controller
Apr 27, 2014 | Heating & Cooling
Cannot set for a second watering time for certain areas of lawn. Have a Orbit 6 Station. Certain areas of lawn have been replaced and require additional watering.
Set up a B Program for the zones that need extra watering.
Say you want zone 2 and zone 3 to run 20 minutes every day in addition to your normal watering.
Set B Program, put Z2 and Z3 time of 20 minutes in, set a start time that is away from your normal watering time, say 6:00 pm. Set every day watering.
Your normal program will water and Z2 and 3 will water every day, too.
Gary
Jun 29, 2011 | Hardware & Accessories
I have a two zone water baseboard system... I installed a new zone valve to the upper zone which was not calling for heat.. the only heat it got was when the lower zone was circulating... Now the upper...
Good clues to work with--
Let's review how you wired up the Zone Valves, in relation to the Boiler Control panel...
You say the upper zone does NOT SHUT DOWN--
Does that mean it is OPEN ALL THE TIME?-- (even when the circulating pump is OFF? )
That sounds like the thermostat is not even in the circuit, then.
Have you been able to cycle each of the valves thru their cycles-- Open- and then closed?
-- It almost sounds like you have an interconnection between the two valves-- is this possible?
Each Thermostat has to control its valve only...
and most systems do this thru a control panel at the boiler--
So-- How is your control panel connected to the 2 thermostats, and how are the 2 zone valves connected to the Control board?
Are you following a wiring schematic for hooking the valves and thermostats to the control board?
There should be a schematic with the new valve you must installed, right?
did you wire it like the instructions showed?
Make a few more tests, and get back with us--
Mack B
Jan 18, 2011 | Heating & Cooling
Amtrol 41 hot water maker :not working when calling for hot water,contols are on showing temp,but tank is cold.oil fired boiler is fine,the whole system is 5 yrs old.
The problem is probably with the circulator pump or the zone valve, which ever way your water circulating from the boiler is controled.
The water needs to be moved through the boiler and the coils in the Hot water maker to heat water. If this is not happening then no water will be heated.
Check for power and then is the pump is running or the zone valve opening.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 21, 2009 | Dishwashers
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Rainbird Rain-bird Esp-40sat Lawn Sprinkler Irrigation Controller 40 Stationcam-link Logo
582 people viewed this question
Top Rainbird Garden Experts
Ted Maxwell
richie46
Gil Shultz
Are you a Rainbird Garden Expert? Answer questions, earn points and help others
