Question about Garden
Will not start
Changed the battery, solenoid, and 20a fuse. Still when ya turn the key it clicks one time that's it
  • 3,289 Answers
It could be a poor / dirty / loose connection at the battery post / cable or starter solenoid. Remove and clean mating battery post / cable surfaces and and those at the starter solenoid.
Posted on Apr 24, 2015
I have an 89 ford bronco and it wont turn over
Fords require 10 + volts to activate the solenoid.
A faulty solenoid, weak battery, or bad connections can cause the solenoid to click. Especially a battery with a dead cell that looks like it is charged.
If the solenoid is clicking the neutral safety switch is ok. If you are only hearing relays click, take a test light and check the 16 gauge wire on the solenoid for voltage with the key in start position.
Also jumper that post with the battery post on the solenoid to crank the engine.
Jun 29, 2012 | 1989 Ford Bronco
I have an '04 Sebring Convertible with the 2.7L V-6 engine. It has been running fine with no problems for over a year since I bought it. Then the other day, I had it detailed and drove it home...
This happens all too often on the Chryslers, the starter fuse blowing. The cause in most cases is the starter solenoid. I recommend replacing the starter and the solenoid when this happens, to keep from having to do it again a few months later, I hope this helps.
Jul 21, 2011 | 2004 Chrysler Sebring
20a fuse replaced, makes a clicking noise when
the starter could be bad take a medal hammer tap on side of starter see if that help if it works & starts then the starter is going bad & may need to be replaced but you can also have a bad starter sylinoid
Jun 26, 2010 | Garden
My 98 dodge neon will not start., when i turn the key i can here the solenoid click but the car will not start, the battery tested good. and all ther fuses were fine also. do i need to change the starter.
Try finding someone to help ya on this procedure. While another person tries to start it, lightly hit the starter and see if it starts to work. If it does start working, then the starter is defective. If it dont start cranking over then check your battery cables for damage, lose or corrosion. Good luck.
Feb 05, 2010 | 1998 Plymouth Neon
Cub cadet 2160 when turning ignition switch in second position, starter motor starts spinning. blows 20A fuse
You have either a short in the solenoid trigger circuit, and a faulty solenoid. To check, disconnect the small trigger wire on the solenoid. Turn key to 'START'. If fuse blows, there is a fault in the wiring. If not, the solenoid is faulty.
Oct 31, 2009 | Garden
1998 subaru clicks when starting
The starter solenoid is clicking so your ignition switch is okay. You've changed the starter? Apparently the solenoid is separate from the starter. Check that the wire from the solenoid to the starter is intact and make sure the ends are nice and shiny. Then it's probably the solenoid itself. Some cars have a fused wire, notably older Fords where the wire itself is a fuse. Your "Snubaru" dealer can tell you.
Jun 10, 2009 | 1989 Subaru Gl Wagon
Trouble code ch6 oil on hour meter
Sounds like your oil low switch is either bad or maybe wire was knocked off when changed oil.
May 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Sep 16, 2008 | 1995 Ford F150 Styleside Regular Cab
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
