Question about Rowenta Power Duo Iron
How do I get the iron apart? removed screws and got the stand base off, but can't get the rest apart.
4 Suggested Answers
  • 19 Answers
SOURCE: The iron leaks from the base when at rest (up
THAT SHOULD HAVE A WARRANTY. SEE THE STORE MGR. WHERE YOU PURCHASED IT.
Posted on Apr 22, 2009
brnspncr
  • 67 Answers
SOURCE: electric cord needs replacing on Powerglide
probably cheaper in the long run to buy a new one. Wallmart have a range of irons under $10.00
Posted on Jun 11, 2009
rohntech
  • 422 Answers
SOURCE: i have a hinari steam generator iron and the steam
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Posted on Jul 13, 2011
DISASSEMBLE SHARK G1465D ELECTRIC IRON
there are 4 screws that you can see and two more under the large rubber stand off at the bottom. I also need you post the wire in the back because I took mine apart and now don't remember the position of the wires
Jan 23, 2012 | Euro-Pro Shark GI490 Iron
Tip
I just took apart a Sunbeam iron. This is how it disassembles: first remove the...
I recently had a problem with the steam button. It somehow during normal use came off its track in the handle and was stuck down in the "slot". After several searches online and this site i tried a knife along all the edges trying to figure out how to disassemble the iron. Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.
on Jun 11, 2011 | Sunbeam 4214 Iron
My wife's sunbeam microglide iron does not get hot. What could it be the problem?. Mauricio. Thanks.
first remove the screw at the base. Next remove the moisture dial top (it should just pop off). This allows the iron to slide apart - the metal base from the top. It should slide about an inch then lift off.
My iron didn't get hot, and what I found is the gear that attaches the temp setting to the electrical was missing a tooth. Perhaps you could set the gear to permanently "ON". In my case I found out with brute force how the iron is supposed to disassemble... time for a new iron...
Mar 27, 2011 | Sunbeam 4214 Iron
My Oreck Cordless Iron leaks constantly. What can I do to stop the leaking?
Find where the leak is coming from, and coat the leak or crack with silicone.
Jul 29, 2009 | Oreck Cordless Speed JP8100CA Iron
Apr 22, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Mar 17, 2008 | Sunbeam 4214 Iron
Taking a Rowenta DX1900 Apart
To get the base off, you have to remove the 2 screws from the face.
the button for the reel has a screw behind it, that needs to be removed.
Take a thin piece of metal, like a spark plug gapper, and slide it in the side to push back the tabs. You have to do it on each side. Remove button and take out screw. The base will come off.
Now you need a special torx srewdriver that allows for the center of the screw to enter the screwdriver.......
Learned the hardway and didn't have the correct torx..... Good Luck
Feb 27, 2008 | Irons
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Rowenta Power Duo Iron Logo
120 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
