Question about Sylvania Televison & Video
My tv is controlling itself it keeps bring up the settings and changing through the inputs I have a sylvania lc320slx
    Top Expert:
  • Sylvania Master
  • 74,251 Answers
Try a Hard Reset to this TV; and check. If it do not help you, contact any service technician. The main system control memory IC to it might be faulty; and has to be replaced. This is not a user repairable one.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 24, 2015
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
mugofjoe
  • 18 Answers
SOURCE: Do you have the remote code for a Sylvania
If you are programming a universal remote, normally they have a chart with the remote. However the codes are as follows:
0054, 0030, 0020, 0028, 0065, 0096, 0381
also the manual is located here: http://www.sylvaniaconsumerelectronics.com/pdf/manual/LC320SLX.pdf
hope this helps.
Posted on Jun 06, 2009
  • 10 Answers
SOURCE: remote code for att uverse to sylvania lc320slx lcd tv
My solution might be a little off because I called Comcast for the answer but it seems that the problem is that the code doesn't exist.
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
Posted on Dec 20, 2009
  • 10 Answers
SOURCE: I need a remote code for my Sylvania TV. LC320SLX
The Sylvania rep anticipates a new code written soon because this is such a prevalent problem.
SOURCE: direct tv remote code for Sylvania LC320SLX
Get the Direct TV RC65 and program in code 11864. It works I just programmed my LC320SLX.
Posted on Jan 01, 2010
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
Remote code sylvania lc320slx
0510 0447 0810. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 30, 2014 | Sylvania LC320SLX 32 in. LCD TV
This tv scans through all inputs. What do I need to do to fix the problem?
Hello; If the set scans the inputs by itself and you can't stop it there are only 3 things you can try. Take the batteries out of the remote control to see if it stops. The next is to take apart the set to see if the input select button is shorted or " wedged " on , if the set even has this button on it. I also assumed you " Replugged the set" If not , probably you should replace the set. John
Jul 07, 2011 | Sylvania LC320SLX 32 in. LCD TV
My lc320slx is about a yr old and two days ago we were sitting watching tv and all of a sudden the channels started rsndomly changing, I thought something was on the remote control but there was nothing....
The control on the television itself is probably dirty or malfunctioning. Unplug the television and remove the back. Find the board underneath the buttons on the TV and gently clean off any dirt using rubbing alneeded and cotton swabs if needed.
Apr 24, 2011 | Sylvania LC320SLX 32 in. LCD TV
Need the directv remote control code lc320slx
hi! i have a cople of codes here for your tv, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465, 1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!!
May 16, 2010 | Sylvania LC320SLX 32 in. LCD TV
I have a sylvania LC320SLX tv and cannot program it with a DirecTV RC64 remote. I saw on your fixya.com site that 11864 works with a DirecTV RC65 remote and wondered if you have tried it on the RC64?...
These codes control Sylvania TV with the RC65, & I suspect they work with the RC64: 11864, 10171, 11271, 11314, and 11394.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Feb 12, 2010 | Sylvania LC320SLX 32 in. LCD TV
I cannot locate the remote control code for my TV
you can get another one from your cable server,or you can get a universal remote
Jan 08, 2010 | Sylvania LC320SLX 32 in. LCD TV
Remote control code for sylvania lc320slx
I has the same problem. I bought a Logitech harmony remote and it works with the tv and everything. The 650 was only $49.00. Well worth it to have one remote.
Nov 22, 2009 | Sylvania LC320SLX 32 in. LCD TV
Without a remote how do I change the inputs on the sylvania tv model lc320slx?
You can use the channel down buttons on the television it self. If you keep going downward or all the way to the end you will most likely run into like vid 1 vid 2..etc....
Nov 09, 2009 | Sylvania LC320SLX 32 in. LCD TV
Televison & Video Logo
107 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
