Question about Water Heaters
Why am I continually blowing 3 amp fuses upon energizing the unit?
I purchased this from an individual who decided not to install this. All components were new in the box. I followed the step by step instructions pertaining to the install.
  • Butch Toll Apr 26, 2015
    Short found to be coming from somewhere in the control module. Unfortunately for me the short circuit was found to be the main control board. Realizing there was in fact a short circuit stemming from the control board I attempted to verify by unplugging and then re-plugging everything to test for issue. With everything unplugged from the board I replaced the blown fuses and plugged the unit in to test the board, and immediately blew both fuses. From there I knew I didn't need to plug anything back in. Thank you for your assistance.
    Top Expert:
  • Water Heaters Master
  • 42,623 Answers
Put a multimeter on the out let side of the fuse holder to earth and check for a short circuit
If you get a resistance reading then maybe the fuse size is incorrect
contact the manufacturer service division on line and get the correct fuse size for the application
Posted on Apr 23, 2015
Blowing fuses on rheem rtgh 84dv
Call service technician
Check polarity of 120 volt outlet
Call Rheem for new PC board
If the 3A glass fuse located on PC board is blowing, then something is drawing too much current or shorted on board... problem is probably bad PC board
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Oct 12, 2014 | Rheem RTGH-84DVN Indoor Direct Vent...
Blown 24v Slow Blow Fuse
Scott, I have the exact same problem. What ended up fixing this? Thanks! - Paul
May 10, 2013 | Honeywell Triangle Tube Prestige Solo 110...
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
Whirlpool 6th sense natural gas water heater 50 gal. Bought brand new today. Upon installation, discover low gas pressure running to unit. Turned out that gas line had under ground leak so had to turn...
1) Be careful before you Call Whirlpool 1-877-817-6750.
Be careful what you report so not to void warranty because installation protocol was not followed. Whirlpool will cover gas control valve, and possibly the installation of valve which takes about 15 minutes and does not require emptying water heater.
************So make sure you report installation that is consistent with installation shown in manual.
2) Whirlpool will also answer this same question later today with invitation to contact them.
3) Copy following link to identify gas control valve, and download service manual:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) If dirt or debris gets into gas control valve, it will cause it not to work. Such as broken gas line. Debris can enter gas line.
Or if too much pipe dope was used on gas connection, or stray teflon tape got into line and then into valve, or end of pipe got dirty during installation, and then dirt got into gas control.
Take off gas line and use vacuum cleaner to see if something can be removed by suction. Clean up the joints.
5) It appears you have ordinary Honeywell gas control valve on atmospheric vented water heater with 9 year parts-labor warranty..
Unknown error code, so it is hard to look up solution in service manual.
Add a comment if you want expert to look up error code in service manual.
Feb 13, 2013 | Water Heaters
Rheem water heater rtg95dvn keeps blowing 3 amp fuses
Not for sure what your root cause was and I know it's a little late but I just suffered this same exact scenario on the same water heater. Storms came through, power went out, power came back on and the water heater keeps blowing the 3 amp fuses now. I removed all the cables and plugged them back in one at a time. When I plugged in the Fan Motor connector the fuses blew. Installed new fuses with the connector out, the Fan Motor was putting out 150 VDC through the connector port (on main control). I pulled the control from the unit and Q1 is visible blown and disintegrated on the control board. Obvious control design issue. I've ordered a new control and will put a surge protector on the heater now when the new control comes in. Very disappointed that this was not caught in controls testing within the manufacturers facility. New control is not very cheap. Half the cost of a new Heater. Hopefully the Fan Motor survived the high voltage with the fuses blowing. I'm putting this here for anyone else that suffers the same issue on this water heater or the Richmond equivalents as they use the same control.
Jul 31, 2012 | Rheem Tankless Hot Water Heater...
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
On Memera fuse box, 30 amp fuse catridge carrier gets very hot, in fact can smell the plastic melting, but why does the 30 amp fuse cartridge (definitely rated as 30 amp) it is carrying NOT blow (240 volt...
OK well at 120 Volts at say 25 Amps (well below blowing potential) that equals 6000 WATTS 6KW, on a near short circuit. going through it...You would melt TOO.
I always use Ceramic ones myself, look they get HOT real HOT, BUT shouldn''t melt.
But in saying that your Electric shower shouldn't draw that much anyway, in reality. it may draw 10A - 15A, at most? more like 5A - 10A,
So i suspect you have a fault to earth somewhere you need to call an electrician. You may just have discovered a very bad fault. Some sort of short or leakage to earth or something?
A shower shouldn't draw anywhere near enough current to cause this type of occurrence. Please disconnect it by tripping the breaker and call a professional. get that melted one changed anyway.
Aug 11, 2010 | Water Heaters
Arcoaire heating/air conditioner continually cycles condensation
a possible solution is to install an air dryer in line with this tube
Jan 03, 2010 | Calvin Klein The Field Controls Company...
Stiebel Eltron tankless 24. Problem:No hot water.Tempature display dead.Single LED on right side comes on when cold water flows thru system.Have cleaned fine mesh input filter.No pressure problems. CCt...
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Oct 11, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
I have a 315l hot water rheem model 111315-it keeps blowing the 20a capacitor fuse in the fuse box every 2 or 3 days every thing else appears to be in good order/no discolour etc would appreciate your...
Hi, Bruce,
Check the required amperage on the data plate on your heater. 20 amps doesn't sound quite right. Test the electrodes for continuity. If one reads open, replace it. Also check your electrical connections where your house wiring connects to the heater. I recently had a heater that arced, and found that the tenant had spilled fabric softener, causing the wiring to short.
Best regards, --W/D--
Aug 06, 2009 | Rheem Water Heaters
Water Heaters Logo
192 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
