Ativa Hd1600 16-sheet Cross-cut Shredder Logo
A
Anonymous Posted on Apr 23, 2015
My Ativa HD 1600 Shredder is stuck on the red light when I turn it on. A little help please?
Whenever I turn on my shredder, the green power button is on. Then it automatically switches to the red light. I have tried pushing the container in all the way, but it still does not work! A little help would be awesome.
1helpful
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Ativa shredder manual
I could not find a manual or support on Ativa website but I searched their FAQ. It said that the shredder basket must be fully closed and integrated with the shredder. I had the same problem. I pushed the basket firmly into place and it stopped. I believe this flashing scheme may be telling you that the shredder and basket aren't properly aligned.
2helpful
Our Ativa HD PRO 1600 shredder will not operate because the "jam alert" light is on, however there is nothing in the feeder or the shredding mechanism. I have misplaced my manual and
SOUNDS LIKE THE SENSOR OR SWITCH MAY HAVE TRASH ON IT.
LOCATE THESE ITEMS USUALLY ON LEADING EDGE CLEAN
SENSOR WITH A "Q" TIP AND ALCOHOL. IF THERE IS SWITCH CHECK
TO SEE THAT IT IS NOT JAMMED AND WORKING PROPERLY.
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
4helpful
DQ83M ATIVA SHREDDER ...LIGHT IS ON BUT DOES NOT SHREDD
The RUN green light is on but no motor is operating for any function of the Ativa DQ 83Mn Shredder. What can be inop?
8helpful
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
2helpful
3answers
Shredder won't turn on
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
2answers
ok " if the ready light did not come on it's telling you that there is no power sound like the plug in transformer is no good .
you can check that transformer , with a multimeter, see if you have the right voltage.
Top Ativa Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
