Question about Cameras
I have a 4 camera started going off and reboot every 5min and shows RH in ch1 what do I do?
  • 3 Answers
Hi, what kind of camera do you have? Please post any available camera info that you have.
Is your battery charged up?
Do you have an empty SD card that properly works inserted into the camera?
Posted on Apr 24, 2015
How do setup so I can fire only main 580 using 600ex-rt as master. the camera is 5D Mark lll. Also if want 2-1 ratio what camera and flash modes should I use. I don't understand the instructio
This video on youtube explains how to setup and use the 600 RT as a master. I do a lot of shooting with master slave, but my equipment is Nikon. Your gear is an excellent choice making it possible to shoot with remote flash. Canon 600ex rt Step by Step Setup Guide
Jan 10, 2015 | Canon Cameras
My LG dehumidifier model LHD45ELT8 get a CH1 error and will not start. he Bucket is empty. Ideas way?
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Nov 06, 2010 | LG LHD45EL Dehumidifier
Unable to change channel DIR-615
IF NO PROBLEMS , WHY YOU ARE UP-TO CHANGE CHANNELS. IF YOU DID NOT STOP FINGERING HABIT THE ROUTER YOU WILL MESS IT UP AND WILL NOT POST ANY QUESTION ON FORUMS.
Apr 11, 2010 | D-Link DIR-615 Wireless Router
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
if you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Active shield
If this is boot up time you need to go to Start / run type in msconfig enter
Go to startup and untick all except for antivirus and firewall and reboot
When you install some programs they put automatically start in and you have to stop them auto starting
this should decrease startup times
Aug 08, 2008 | HP P5750-69001 - System Board/P4...
Another question for zzedly about the speakers cutting out
So, as I see it, your system is hooked up like so:
  • Ch1 = Left speakers, front and back
  • Ch2 = Right speakers, front and back
  • Ch3 = One sub
  • Ch4 = Other sub
One thing you can try is swapping channels. Swap Ch1 with Ch3 and Ch2 with Ch4. Then see if the issue still occurs on the door speakers or do the subs suddenly cut out at loud volume. If the subs start cutting out, that means the issue is with Ch1 and Ch2. If you haven't already, check the RCA connections to Ch1 and Ch2 as well as the gain for all channels. If the gain isn't already set to about 50%, put it there.
Mar 14, 2008 | Kicker IX404 Car Audio Amplifier
Geovision DVR reboots
turn off reboot in system config if cam loss
Feb 28, 2008 | Geovision GV-800-16 Video Capture
Channel Two Input silent
Not sure of particular model, but if it's like z1 then it's convoluted and non-intuitive.
But here goes.. if i can remember.
Go into menu, then audio
check that the channels aren't linked
if set to manual check manual adjustment wheels
The z1 doesn't seem to allow on board mic and xlrs, so check that
Does mic need phantom power?
Is XLR input set to mic?
Sorry i can't be more model specific... but hopefully something of this will be helpfull.. the main thing to check tho is that the xlrs aren't linked
Jan 29, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
