Question about Health & Beauty
My ezip scooter wont go the battery is charged what could be wrong with it?
  • 1,263 Answers
Hi ,is it possible to see a picture of this scooter ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 11, 2015
  • 118 Answers
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
Posted on Nov 27, 2008
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
  • 945 Answers
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Posted on Nov 06, 2009
  • 10865 Answers
SOURCE: I have a pride celebrity
Hello dvaldez. The problem is not with the scooter but the battery. When a battery no longer takes a full charge you generally have to replace it. Any auto parts store will test that battery for you to see if it is indeed the problem. This is a free service. Joe
Thanks for choosing Fixya!
Posted on Dec 05, 2010
  • 692 Answers
SOURCE: I have a mayfair freerider scooter and all of a
try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Posted on Apr 18, 2011
I have a ezip 450 electric scooter doesn't run.I
Check the brake micro switch and brake coil resistance plus all wires in this area.
Oct 09, 2014 | Health & Beauty
Hi I have a ezip 400 scooter we just bought a new charger and the charger has a green light but the ezip its charged I was thing maybe its a loss wire or something I got the ezip from someone said if
Push the circuit breaker back in first. The scooter will not move if the charger is connected. If the scooter has sat unused for a long time, the charger will NOT recover the batteries. Charge them individually with an automotive charger until the voltage is at least 11 volts each. May take a 12 or more hours. If you can't get 11 volts after that time then the batteries are gone.
Oct 04, 2014 | Health & Beauty
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
Brake stuck on
remove first the tire then if will unlock the bake...but clean the brake pad check if still have a thickness in the brake pad.....u
Dec 09, 2013 | Ezip The E-450 Scooter
Quickly loses charge
if its more than a year old scooter thenu have to change the pack of batteries
to check batteries short the both terminals of battery and check the level of sparking
note just a touch of wire from negative to possivte when its fully charged and discharged
Mar 19, 2013 | UPG 12V 10Ah Currie eZip 400, E-400, E400...
On my kaos electric scotter i can,t tell how much battery life i have left or when i need to charge it the battery gauge just stopped working can it be a loose wire someware if yes where would i look
is there a device that tells you how much charge is left in your
battery -can you tell me the name of it i believe Maplins sell them i want it for my Mobility Scooter
Mar 10, 2010 | Electric Currie EZIP 500 Scooter
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Health & Beauty Logo
120 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
