I was changing the bearing, and when I went to remove them they fell out leaving only the outer shell, which I have been unable to remove. Can someone help? Please!
    Top Expert:
  • Washing Mach... Master
  • 50,010 Answers
Find a friend or a shop that has an impact puller ( slide hammer)
fit the fingers of the puller so that they expand out when adjusted into the groove in the bearing. use the slide hammer and knock the shell ( outer race ) out
Posted on Apr 23, 2015
Has a squeek when it is in the spin cycle
mostly the motor problem  and other possible problem can be  that a bearing is bad.If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 08, 2009 | Washing Machines
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Picture1 - Picture2
May 07, 2009 | GE WJSR2070B Top Load Washer
Maytag washer MAV551EEWW top load with loose tub
Picture1 - Picture2
May 07, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Made a loud noise and drum stopped moving
Picture1 - Picture2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
Grime on clothes from washer
Picture1 - Picture2
Mar 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes
check out for this link
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Sep 27, 2008 | Hotpoint Washing Machines
How to Remove the bearing outer race from the shell of the washing machine tub
bearing on most can not be removed there molded in the outer tub comes with the rear half of the tub already installed
Feb 26, 2008 | Kenmore 43052 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
