Question about Samsung Washing Machines
Samsung front loader 8 kg will not spin.
Model WF8802RPF. No error codes displayed. Will fill with water then nothing happens. Can pump out also. Will not spin either?
    Genius:
  • Samsung Master
  • 1,585 Answers
Could be motor brushes or capacator
Posted on Apr 26, 2015
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Samsung washing machine nf Error code
Here is the best troubleshooting manual i've ever seen. It's PDF:
http://downloadcenter.samsung.com/content/UM/201106/20110628141933509/WF350AN-Tech-02834A-02.pdf
I found it here:
https://www.samsung.com/us/support/owners/product/WF350ANP/XAA
NOTE: If water is not entering tub, you almost certainly need to replace the water valve. If water is entering tub but won't fill your drain pump is suspect. Hope this helps.
Dec 30, 2012 | Samsung WF350ANP Front Load Tumble
Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
Oct 24, 2009 | Kenmore Elite HE5t Washer
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
