Question about Refrigerators
Fridge will only start when you tap the motherboard box
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Can be bad connection as previous answer.
Or mostly it can be a relay in the computer board. Need to replace the board in this case.
Posted on Apr 25, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Sounds like a bad connection on the mother board. Disconnect the power, remove and reattach all connectors on the board. look for loose components especially relays. there is a bad connection or bad relay.
I have a kenmore bottom freezer refrigerator model # 795.78304.804 bout 10are11years old just stopped working nothing will come on . checked power at box and it's good
main switch/thermostat control inside of fridge needs replacing...to prove...tap/bump switch a couple of times and you should hear fridge power up...if so replace switch/thermostat...
Oct 16, 2016 | Kenmore Refrigerators
Ge mod GSS22GRC SS the ice maker works fine but all of a sudden the water despenser does not flow....I since changed the filter that did not help
Start by checking the water supply going to the fridge:
  • Turn off the water at the saddle tap valve.
  • Disconnect the water line in the back of the fridge. Place the disconnected end in a bucket and open the saddle tap valve.
  • Observe the flow rate–water should shoot out vigorously. If not, then the saddle tap valve is probably gunked up with sediment and you’ll need to replace it.
Oct 11, 2008 | GE Refrigerators
My Maytag MTB2156DEB fridge died. Electricity is on, lights are on but nobody home, I.E., no cooling. my old fridge had a "reset" button which I found out after the repairman charged a bundle to press. ...
Your model doesn't have a reset button, this is non-electronic. First, tap on control panel to see if cold control is stuck. (tap on beat) If it starts it could be a bad control. Does to compressor click like it wants to start? Lastly, there is a defrost timer within the control housing, with a screwdriver rotate the timer slowly to see if the timer is stuck. If the unit starts running it could be that the timer needs to be replaced. Get back to me and I can help further if needed. Good Luck
Mar 07, 2015 | Maytag Refrigerators
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
I have a GE side by side Fridge that seems to get stuck in defrost mode and thaws the freezer out completely. When I tap the mother board with a screw driver it begins cooling again for a couple of days...
Yes I do believe your motherboard is very likely the problem. These motherboards are a common weak link for the GLS25 and all series of the Artica/Profile. Fact is any refrigerator that uses electronics to control mechnical and electrical functions has this weakness. Things that help cause this problem are failing compressor start components like start relay, start capacitor, defective condensor or evaporator fan motors and electrical surge.
WR55X10656 Board Assembly Main Control
Many times disconnecting power first and examine both sides of motherboard for signs of heat damage or burn marks. Sometimes you can see the bad sections of motherboard but not aloways. Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION
You will need Adobe Reader to open the service manual=> GE PSS26MSRSS Service Manual
This manual also covers your model. Acrobat Reader is available as a free download
If you have any questions or just need assistance in the repair I will be here to assist you, Thanks Sea Breeze
Sep 24, 2011 | GE GSL25JFXLB (250 cu ft) Side by Side...
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
Fridge does not stay cold
Does the compressor ever run? You may have to remove the rear bottom panel to see....
Use this manual to force compressor mode.....
I have had this problem. The control board has a cheap relay that makes the compressor run...The bad part is if your not into electronics you will be in trouble here.
There is a white box that houses the control board....
Unplug the fridge remove the cover....plug in the fridge wait for the fans to start and tap the white box with a screwdriver...you may here the compressor (black round 5X8 cyl..)..
Here's the service manual link
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Feb 23, 2010 | Samsung RB215LASH
Filter not filtering
When you put the filter in, did you let several gallons of water run through it before you started using it for your own use? You're supposed to flush the filter (see directions on box filter came in) before you use the filter for your own purposes.
If you're getting "chunky" water, check to make sure the water coming in from your taps is not sketchy, that your water source (either town/city or well) isn't encountering problems. If that's the case you might need to put in a "whole house" filtering system.
Aug 28, 2009 | LG LRFD25850 French Door Refrigerator
My Fridge/Freezer is turning itself on and off!!!
I think your motherboard of your fridge is going bad. If that is so, then its better to just get a new fridge than tryin to fix it. the motherboard is expensive and this is the brains of the fridge
Oct 17, 2008 | Hoover HCA390FFK Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
