Question about IBM Infoprint 6500 Matrix Printer
As400 LAN printer. queue has status of wrt but does nothing. can ping printer. have end/start writer, turned printer off/on, varied off/on. still will not print.
    Sergeant:
    Habit-Forming:
  • IBM Expert
  • 124 Answers
I'm assuming that you are using an IPDS device description. If so your Ethernet card need to have the defaults reset. There is an option to do this via the printers web interface.
Posted on Jul 07, 2015
2 Suggested Answers
RoryMRP
  • 111 Answers
SOURCE: I have a 4247 printer attached remotely via TCP/IP
1) what do they do to get the printer to start back up agian
2) if you press and hold the button on the NIC card for 5 sec will the NIC print it's self test?
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
3821 W. 127th Place
708-597-4222 X240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 29, 2009
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
Have Z2420 printer appears it's talking with PC says it's printing gives printing status as 20% complete but nothing prints s
It could be due to the print spooler service on your computer. Please follow the steps below on how to clear the print queue and enable the print spooler service.
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 15, 2012 | Lexmark Z2420 Printer
Unable to communicat to AS/400 system which is connected to ibm 3487 monitor
AS/400 printers can be tricky to connect to. Consider the following settings:
The following link has proved helpful to others connecting our ASCII Text only printer to an AS400 OutQ.
http://www-1.ibm.com/support/docview.wss?uid=nas1d6e996c964f3895286256aa10077ebdb
>an AS/400 LPR/LPD Network Output Queue:
>AS/400 OUTQ set up with the following parameters:
>Writers to autostart . . . . . . . . . : *NONE
>Remote system . . . . . . . . . . . : *INTNETADR
>Remote printer queue. . . . . . . . : text
>Connection type . . . . . . . . . . . : *IP
>Internet address . . . . . . . . . . . : 172.23.90.71 (example address)
>Destination type . . . . . . . . . . . : *OTHER
>Host print transform. . . . . . . . . : *YES
>Manufacturer type and model. . : *IBM4212 or 4214, 5256, 5225
>Print separator page. . . . . . . . : *NO
May 21, 2010 | Paxar Monarch 9830 Thermal Printer
Deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Jul 01, 2009 | Dell Inkjet 720 Printer
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
Printer stays in a SND mode
Have you check the firmware issue?
Nov 05, 2008 | Datamax I-4308 Thermal Label Printer
ROUTER CONNECTIVITY
Ok, do a troubleshooting session.
Unplug the router from the internet modem.
Try at first to connect using a Network cable from you PC to one of the LAN sockets.
Can you access http://192.168.1.1  with your web browser?  (the configuration page)
     If yes it is possible that the router has the same address as your adsl modem.
    change the router address to something 192.168.0.1 instead of 192.168.1.1
     Save your changes. Plug your WRT to the adsl modem and try again.
     Does the internet work now with a wired connection ?
If the above does not work can you "ping" the machine ?
      ping 192.168.1.1
if none of that works try doing a hard reset... heres a little guide (off the DD-WRT wiki)
http://www.dd-wrt.com/wiki/index.php/Reset_And_Reboot
Oct 09, 2007 | Linksys Wireless-G WRT54G Router
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
IBM Infoprint 6500 Matrix Printer Logo
80 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
