Question about Bosch Washing Machines
How do I fix a washer that will suddenly lose power and then a few minutes later the lights will come back on and then go out again.
I try to run it and it will run for a few seconds but then all lights will go out. Then after a few minutes you can get the lights to come back on but it will only stay on for a few seconds.
    Genius:
  • Bosch Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 26, 2015
My Ford Transit Diesel 2007 (camper van)intermitantly loses power and the Engine Malfunction light comes on. If I stop, turn off the engine and restart it a few minutes later everything goes like a ch
When the engine is under load it uses more fuel then normal .First replace the fuel filter then check the fuel pressure and flow. the pressure and flow are checked with gauges. For a rough check remove the return pipe from the fuel rail, if fuel is flowing there the fuel system should be ok providing the pressure valve is not stuck open. if there is no flow there the pump may be at fault.
Nov 13, 2014 | Cars & Trucks
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
Lost power suddenly, idles but will not accellerate
Have your fuel pump and fuel filter replaced. If you let the truck sit off for 30 to 45 min; and then try to start it and drive, it should run again but only for a few minutes before losing power again. This is caused by the fuel pump overheating.
Oct 19, 2011 | 1999 Ford Explorer
Engine runs for a few minutes then stalls...
It sounds like vapor lock or other lack of fuel. Premium gas will cause detonation and "may" have something to do with it. Drain the fuel the best you can and add regular fuel, after a couple minutes the engine should be burning mixed fuel and if the problem goes away you have fixed it, if not you obviously have other issues.
Jun 19, 2010 | Craftsman 2500 PSI Briggs Stratton...
Speedometer and tach suddenly dop..more like flutter..to zero
must be losing ground on it check body ground
Oct 01, 2009 | 1998 Saturn SL
Pressure washer sputters and stalls when trigger is engaged
Hi k2times01
It is a always a good idea to clean out the gas tank and use new fuel, however, this sounds like an RPM problem. Try adjusting the RPM up a tad and see if it runs better when you load it. If the RPM isn't the problem, you may have to clean the carburetor thoroughly.
Jul 15, 2009 | Garden
Washer won't work after power outage
Inspect your motor. It maybe going thermal cutoff. Overheating this will pop the C/B. The motor will run for awhile until it heats up. When the motor colds down it may work for a few minutes.
Feb 10, 2009 | GE Washing Machines
Washing Machines Logo
52 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
