Question about Dishwashers
Hi. Flash light On my Adp 4425 blink flash light for 3 times. It tales water bit them start to blinl and wan't wash. Thank you for answer.
  • 209 Answers
SOURCE: Kenmore Ultra wash model 665 17779990-Cycle wont finish- Lights blinking
heater element if its not warming up, you didn't say, if it worms up then check the pump
Posted on Oct 15, 2007
SOURCE: Flashes 8 times ADP 5340
Again Pressed the main button for about 15 sec that did reset the fault
larf
Posted on Apr 21, 2008
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
SOURCE: Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
Posted on Aug 06, 2009
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Why does my Diplomat ADP 8902 dishwasher beep twice when i switch it on and the 4th wash program light flash and do nothing else?
Can I say thank you for the above advice. Hit the programme button 4 times and closed machine. Now running rinse cycle. Let hope it works afterwards. Will post ant let you know.
Nov 20, 2010 | Dishwashers
My ADP 8342 continually sounds 10 beeps, stops the...
Refer the user guide for the error message meaning. Contact service provider.
Before that make sure that the water supply to the inlet is having free flow.
May 21, 2010 | Dishwashers
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Wil163 3 lights flash mid wash
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Apr 12, 2009 | Indesit WA 115 Front Load Washer
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
My dishwasher model adp 941 won't start - start led flashes
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Oct 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Flashing light
Aug 08, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
