Question about Maytag Refrigerators
Maytag mbf1958XEB1 temp control panel seems dead just displays a dash mark in the temp boxes
    Guru:
  • 310 Answers
We have some refrigerator control boards in stock, or we can rebuild your control.
http://www.fixyourboard.com/in_stock.html
Posted on Sep 01, 2015
2 Suggested Answers
Todd_pdx
  • 22 Answers
SOURCE: maytag PBF2253HEW temp control lights blinking
Your heading has two model #'s if your dealing with a PBF2253HEW you need a new jazz board pn W10165748 this part also controls your automatic defrost cycles if lights are flickering you should replace prior to something else going wrong
Posted on Apr 02, 2009
Need fuse box diagram
Some fuse boxes have a diagram on the box cover.
Hope this is true.
Mar 30, 2015 | 1992 Mercury Sable
1995 buick park ave. 3800 series II. After letting the car reach full temp I turn on the heat and it is nice and warm for about 30 seconds, then I hear the sound of the air change, and the display...
Hello: The air mix door/temp door actuator has stripped gears and the force of the air by the blower motor is pushing the door to the Air Conditioning position. If you will remove the glove box and the panel under the dash and start the car and duplicate the condition you described you will see the action. you will need to replace the actuator. If you have passenger temp control then you will have two actuators, the one on the bottom for driver and the one on top for passenger.
Jan 20, 2011 | 1992 Buick Park Avenue
Runs all the time and seal is hot
sounds like the defrost timer is stuck on defrost while the cooling cycle is engaged this could be from a faulty limit switch in the defrost element circuit! to a temp controller in the freezer unit......you have to remove the inner boxes and panels to get too this area takes a lot of time and patience as to not break the plastic panels
Jan 13, 2010 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MZD2665HEW ADC replacement
You will find the defrost control board inside the panel that contains the two turn knobs where you control the temp inside both compartments. It's inside your fresh food section of your unit. Pull the two knobs off, take the screw out of the side and remove plastic piece. Between the two temp controls there is a square box. The board is located inside the box. Take box apart and replace board.
If you would like a parts blowup of the unit, go to www.partselect.com and enter your model number. Select the Control panel to the left. This will give you a blowup of the parts.
Please rate solution
Sep 10, 2009 | Refrigerators
Lost instrument display - ODB II Code P1689
P1689 No Communication between ECM & Ins
P1689 - Indicates a Data link failure between ECM and fuel injection pump. Low power, engine dereated or engine stops.
POSSIBLE CAUSES:
  • Fuel Inj pump Gnd ckt open or high resistance
  • Fuel pump ctrl mod harness observable defect
  • Datalink (+) circuit open
  • Datalink (+) circuit short to ground
  • Datalink (-) circuit open
  • Datalink (-) circuit short to ground
  • Engine control module defective
Hope this helps. Check the fues box under the hood and under the dash on the drivers side. Look for any bad corrosion or bad fuses.
May 13, 2009 | 1999 Dodge Grand Caravan
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
My maytag dishwasher appears dead just after 1 year
You probably have a bad main control or console control unit in there. Turn power off to the machine, be sure that BOTH of your door switches are ok. Unplug your membrane to control panel ribbon cable, then put everything back in place. Leave the door open, then turn power back on to machine. (also, be sure the thermal fuse hasnt tripped while your in the console). After re-appling power, close the door, and wait a few, if the console unit is bad, the machine will go into drain mode (you will here the unit start in drain). If no drain mode, then your control is shorted. You dont have to see any burn marks, etc for one to be bad, in fact, 98% of the boards we replace, dont show any signs of problems. Let me know what you find out.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
We have an Amana Side by side purchased in 2000. went on a 2month vacation, and turned the freezer temp down, and when we got home turned it back up, and now it won't keep the Ice Cream frooze, everything...
IS THERE A FROST BUILDUP ON THE BACK WALL OF THE
FREEZER INTERIOR? IF SO, AMANA IS MADE BY MAYTAG
AND THE ELECTRONIC BOARD THAT CONTROLS THE DEFROST IS MOST LIKELY SUSPECT. IT IS LOCATED IN THE UPPER RIGHT CORNER OF THE CONTROL PANEL IN THE REFRIGERATOR SECTION {INSIDE BACK RIGHT CORNER).
THE ENTIRE UPPER PANEL HAS TO BE REMOVED TO GAIN ACCESS. WHERE THE WIRES CONNECT, THERE ARE 2
TERMINALS MARKED TEST. SHORTING THESE TWO TERMINALS WILL ACTIVATE THE DEFROST MODE OF THE CONTROL. IF IT FAILS, REPLACE THE CONTROL.
Mar 27, 2008 | Refrigerators
EE IN TEMP DISPLAY
I just called a maytag repair store, and they just had one in the shop, it sounds like the control panel has died, and will need to be replaced. They cost around 60 dollars, + install fee.
Jul 05, 2007 | Maytag M6Q10F2A Air Conditioner
Refrigerators Logo
106 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
