Purple code - Computers & Internet
    Brigadier General:
  • 3,400 Answers
Posted on Apr 24, 2015
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Code purple when turning on computer
Code Purple is a problem exclusive to HP's, the easiest solution is to avoid them. However, it's already too late for you as it was for me. Basically it's an attempt to force you to pay them to service or upgrade your PC, or if you didn't learn the first time, buy another. Here is the most concise answer I found, tried to translate into plain english.
***PLAIN ENGLISH QUICK AND EASY FIX FOR ALL SYSTEMS****
***Windows 7 code purple or Windows Vista code purple***
With the code purple error on the screen, press shift+f10 (the shift key and the F10 key (at the top of the keyboard) at the same time) to open a little screen called a command prompt. (So, you get a little black screen with white text that says something about your Windows verison first and a little ways down you'll see "C:\>". It's all ready for you to start typing.)
Type the following line, just as you see it here...
notepad C:\hp\bin\checkdmi\checkdmi.cmd
so it will look like this C:\>notepad C:\hp\bin\checkdmi\checkdmi.cmd - Note the space between notepad and C:\
Press Enter.
You will see the text for the file listed in a window using a simple text editor.
Go to the beginning of the text. Press enter to make a space. Type this...
goto cleanup
So, whatever comes after, the first line looks like this...
goto cleanup
Save the file and exit notepad and restart your PC. You are good to go
NOTE: From my experience. If you received the Code Purple error during the restore process; after saving and exiting notepad, press and hold the power button until the PC shuts down, wait 15 seconds then restart. If you get a message during start up select "start windows normally". If you don't shut down using the power button and wait for the "windows was unable to finish........", you will likely get the same error again when the system boots. I don't know how to get back to the Code Purple error without doing the restore process again.
Feb 10, 2013 | HP Computers & Internet
How to fix code purple error
"code purple"? In what kind of computer?
Dec 24, 2012 | HP Hewlett Packard Pavilion A6200N PC...
The code purple shows up on my computer hp desktop
The following error message opens after the PC is started after a recovery: Your system has detected a configuration error. Please call your Customer Care Center number, located in your Warranty and License information, for technical support. (Code Purple) contact hp tech support...meder's tv service Figure 1: Code Purple error c00372799.jpg
Aug 29, 2012 | HP Computers & Internet
The code purple on my computer
Code purple is because an O.S other than a genuine HP has been installed and as it is HP it would have to be HP as it is designed especially to run HP computers only, For example if you try to install an O.S from a Compaq even though Hp and Compaq have merged it is written for Compaq computers not HP and vice/versa. Re-Install your original HP O.S and this should sort out the code purple error. I hope this helps.
Code Purple
it look like a trojan you need to check for virus and malware
Oct 11, 2009 | HP Pavilion m8020n PC Desktop
Code purple
code purple is a hp and compaq term meaning the machine has detected an error in hardware(adding card etc) the mb's are tatooed and usually the machine is sent back to be re tatooed.sometimes installing the microsorft version of the software, after a format (no restore disk) will stop this from happening.
Jul 21, 2009 | HP Computers & Internet
Code purple
long story of why
but to fix it.......
take you hard drive out of your computer and install it into some one else's computer ussing the CD/DVD cable( or use an IDE/SATA to USB adapter).
When you have your drive in their computer Search for the file run.py. rename the file run.p_. Take the drive bake to yours and reinstall. Reboot big sigh....
Feb 02, 2009 | Salomon Code Light Snowboard Bindings...
I have a 96 s-10 that has a code alarm 1000 SE.
Look for purple wire in the ignition harness, it will be cut going to a relay and then back to the opposite side of the purple wire, cut this out and connect purple to purple... it will start every time now (provideing this was the propblem)
Jan 22, 2009 | Code-Alarm Code Alarm Transponder
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
