Question about Magnavox Televison & Video
Can I stream Netflix onto my Magnavox tv model 19mf338B/27
Trying to stream Netflix from my Macbook pro via a HDMI cable- How can I do this?
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
operas
  • 123 Answers
SOURCE: Free 32" Magnavox TV Manual
try these linkswww.ebookspdf.com/search/dopod+810/page/7/www.scribd.com/doc/6420346/Panasonic-TC37LZ800-manualjavascript:;
Posted on Jun 13, 2009
  • 1587 Answers
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Posted on Oct 13, 2010
Testimonial: "Thank you for giving me another avenue to explore."
cgirald2
SOURCE: no hdmi sound from macbook pro to toshiba 40E210U
I was having this exact problem. You have to go to the "Audio MIDI setup" icon in the utilities folder. plugin your mac to the HDMI and TV and it should show up on the menu bar on the left as "HDMI"- then click it. then you have to click on the "format" drop down menu and change it to either 48000.0Hz or less. Make sure that the volume is down on your TV bc I almost gave myself a heart attack when I clicked it. Apparently the TV HDMI input is not compatible with the default on the Mac. Hope this helps!
Posted on Jun 12, 2012
Hooked up to netflix to phone and TV yesterday and all worked fine. Today tried it and it won't play on the TV will only play on the phone. How do we fix
Google Chromecast HDMI Streaming Media Player (2014 ...
www.walmart.com/...Chromecast-HDMI-Streaming-Media-Play...
Walmart
Rating: 4 - ‎1,760 votes
Buy Google Chromecast HDMI Streaming Media Player (2014 Model) at ... This plug-and-play media player allows you to cast your favorites from Netflix, ... It automatically updates to work with a growing number of apps. ..... I love not having to put my laptop next to the tv and hooking up hdmi cords to play .... Mobile apps.
Google Chromecast: What Is It and How Do You Use It ...
techforluddites.com/google-chromecast-what-is-it-and-how-do-you-use-it/
Dec 16, 2015 - The Google Chromecast is a streaming media player, which means it... But there are many other top content providers that work with it as well, includingNetflix, Hulu, .... and use your television remote (NOT your Roku remote) to switch to that ... I set mine up using the Chromecast app on my Android phone.
5 Easy Ways to Get Netflix & Other Video Streaming ...
www.techlicious.com/.../5-easy-ways-to-get-netflix-video-streaming-serv...
Feb 27, 2015 - For laptops, just plug it into your TV with an HDMI cable. ... GoogleChromecast to top-of-the-line Roku 3, Apple TV, and Amazon Fire TV. ... To decide which one is best for you, you'll want to not only look at the features on offer, but to also ... Here are the best streaming media players on the market today.
How to set up a Chromecast - CNET
Jan 06, 2016 | Google Chromecast HDMI Streaming Media...
What cable is needed to stream Netflix to a Macbook?
If you want to use a TV as a secondary or mirrored monitor. All you would need is a Mini-DVI to HDMI adapter. Use the adapter to connect an HDMI cable between your computer and the TV. Once connected you will have an option to use it as a secondary or mirrored (exact copy of what is on your laptop) monitor. If you have one of the newer macbook pros you need a Mini Display port to HDMI adapter.
Jul 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How does one stream netflix via Blu Ray wired to ISP through a tv?
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
May 04, 2014 | Samsung BD-E5400 - Blu-ray disc player
Pro 435pu
that should find it automatically just turn your computer on and tv and set to hdmi 1 or whatever it should be there shoud no have to set anything up if it is a newer macbook pro or something , goto youtube if this does not work
Mar 28, 2014 | Televison & Video
Can i watch netflix on my KDL-32EX524 UKA bravia tv?
To watch Netflix you need a (Netflix subscription of course) and a Smart TV with the Netflix app running or if you have an older TV you will need a streaming device like Amazon Fire TV http://www.amazon.com/gp/product/B00GDQ0RMG?ref_=ods_gw_d_h1_tv_montoya_dualUR
which plugs into your HDMI port to access Netflix via a wireless internet connection. The setup is pretty easy. Hope this is helpful.
Nov 15, 2013 | Netflix
How to stream media from macbook pro to lg smart tv
From what I can see, there is no way to stream to this TV from any computer. You'll most likely have to buy an adapter cable to allow you to connect your Macbook Pro to one of the HDMI ports of the TV.
Jan 28, 2012 | Computers & Internet
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
44 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
