Question about Clothing Accessories
Retuned2 pirs of Sechers an you are just rfnding for one pair
    Master:
  • 965 Answers
I am not sure who you bought them from, but it is best to speak to the people youg gotthem from about this question
Posted on May 08, 2015
Instructions for pro symmetric pir
If it has a sensor adjust the sensitivity down and it will help it if not fix it
Sep 06, 2014 | Electrical Supplies
PIR switches and house wiring is incompatable?
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
Feb 23, 2014 | Electrical Supplies
Reset instructions for PIR floodlight
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
Nov 24, 2013 | Televison & Video
How do i use the flash so it will take pics at night? and what does PIR mean on the menu shouldi set Hi Lo or Med?
hi ,ill be suprised if theres a flash , it should just automaticly switch to night vision using infra red light,, as for PIR,,p.i.r stands for
passive infra red,, its like a beam that when disrupted will switch something on , in your case, "take a shot"the high medium and low just refer to sensitivity,,mouse , cat, dog . elephant ,
Oct 15, 2013 | Wildgame Innovations Axe 2 2Mp Game Camera
Pir connection
Can't see how that should be any problem. Use the switch from the PIR to turn on and off the power supply. Not after the 12v but before
May 28, 2013 | Computers & Internet
Wiring diagram for a p i r to a light
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Jan 17, 2012 | Home
PIR is only working at about 1ft from unit how can I change this
It sounds like it may be bad. Typical PIR sensor's range is determined by the lens. It's possible it may need cleaning. Most have the front half of the PIR snap on or there will be a screw in the bottom. Opening will allow you to check behind the lens for spider webs or other obstructions.
Good luck.
Mar 17, 2011 | Home Security
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
Dec 31, 2009 | Apple iPhone 3G
Cannot connect bluetooth handfree
First you have to enable the Bluetooth to scanning mode,
To do this, press and hold the power button continously for 10 seconds,
You may have a stable LED, this shows that its in discoverable mode,
Now perform scanning and you may get your device and you can pair and make it work to pir with defaulr code ie, 0000 or 1234 or 8888
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Oct 15, 2009 | Samsung SPH-M300 Cellular Phone
Samsung d500 cant turn off quiet mode
Lund pe zoor zoor se chalangay lagao mobile teek ho jayaga agar pir b teek na hoo to lund ko chooso aur pir apni gand me gusao mera. Thanks
Aug 14, 2008 | Lands Phones
Clothing Accessories Logo
41 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
