How can I remove a timer knob off a stackable White-Westinghouse washer? I tried to look for a pin/screw but could not locate it. Thanks Andy
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
Pull it off
Posted on Apr 23, 2015
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
I have to replace the timer knob on my whirlpool LTE5243DQ3 combination washer and dryer,but I cannot remove the old one
oh boy these are varied in the way to remove them, but usually under the knob is a pin, or screw and in some cases a u shaped plastic pc that locks timer to knob shaft? in some cases on the back side the shaft has to be pulled up then remove the locking pin or u shape piece to release it and wow it comes off
Aug 19, 2014 | Whirlpool 27 " White Combination Washer...
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
How do I get the timer knob off
there is a center pin in the timer . take the two screws out of the two corners of control panel . pull toward you and lift up to open panel . remove safty clip in center of timer and pulll out red slip pin . this will release timer knob . under the knob is 2 more screws that mount timer .. mm
Dec 24, 2009 | Kenmore 23822 Top Load Washer
How do you remove the timer on a Whirlpool washer
You have to unscrew the knob and remove the screws that are under it, some have just a center nut with a locating tab that goes into a hole to hold it straight.
Oct 24, 2009 | Whirlpool Washing Machines
Clogged screen for White Westinghouse washer
the screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Can not get the upper right dial off. It needs to be replaced.
remove console by taking 2 screws from the rear of it out, timer knob can be removed by squeezing pin at the center of the timer and pulling knob forward. Probably the timer needs replacing
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
