I want to round 921444 to the nearest on hundred thousand
    Sergeant:
  • 317 Answers
900,000
Posted on Apr 23, 2015
    Top Expert:
  • 10,875 Answers
921444
  • 8073 Answers
SOURCE: ACME Skateboards Inc., has paid
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Posted on Oct 04, 2009
SOURCE: i need to round 301,421,
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Posted on Aug 19, 2010
thehappydog8
  • 50 Answers
SOURCE: what is 27,415 rounded by
27,400 is the answer
Just like rounding your 10's
The breaking point is at 50 instead of at 5
So if the number was 27,465 it would be 27,500
Posted on Jun 23, 2011
Elessaelle
  • 122 Answers
SOURCE: how to round-off this number
That's 8,110,000.
Posted on Sep 05, 2011
  • 37 Answers
SOURCE: 4136 rounded off to the nearest hundred
4100
It would need to be 4150 or more to round up to 4200.
If your calculator has a function for rounding to the nearest integer, you will need to divide by 100 first, then round, then multiply by 100 again.
Posted on May 29, 2012
617,889 rounded to the nearest hundred thousand
You would round that down to 600,000, since 17,889 is closer to 0 than it is to the next 100,000. It's not even halfway to the next hundred thousand. so, you round down. See...? ;-)
Sep 20, 2017 | The Office Equipment & Supplies
159.501 rounded to the nearest thousand?
Calculators usually have a position switch to do it for you.
Rounding Numbers to the Nearest Thousand - AAA Math
www.aaamath.com/g3_41cx1.htm To round numbers to the nearest thousand, make the numbers whose last three digits are 001 through 499 into the next lower number that ends in 000.
Feb 16, 2015 | Office Equipment & Supplies
What is 82,596 rounded to the hundreds, tens, thousands, and ten thousands.
Rounded to the nearest hundred: 82,600
nearest ten: 82,600
nearest thousand: 83,000
nearest ten thousand: 80,000
Sep 17, 2014 | Office Equipment & Supplies
I neeed to round 740,692 to the place value
Round to which place value?
To the nearest million: 1,000,000
To the nearest hundred thousand: 700,000
To the nearest ten thousand: 740,000
To the nearest thousand: 741,000
To the nearest hundred: 740,700
To the nearest ten: 740,690
Sep 02, 2014 | Office Equipment & Supplies
Round 91, 284; hundred thousands
91,284 rounded to the nearest hundred thousand is 100,000.
Aug 28, 2014 | Office Equipment & Supplies
How can i round to the hundreds or thousands?
Put the calculator in scientific display mode (SHIFT>MODE(Setup)>FIX. You will be asked to enter the number of fixed decimal digits. Enter 2 for hundredths, and 3 for thousandths. To round to the nearest hundreds or the nearest thousands, do it by hand as follows.
For hundreds
Locate the hundred digit. Let it be h.
If the next digit (the tens digits is less than 5 replace the 10 and unit digits each by 0. Your result will look like ...h00.
If the 10s digit is 5 or above (5, 6, 7, 8, 9) you must round up by increasing the hundreds digits by 1. Your result will look like ...(h+1)00
For thousands
Let the thousand digits be t
If the hundreds digits to its right is less than 5, replace it and the digits following it by 0. Your result will look like ...t000.
If the hundreds digit is 5 or higher, increase the thousands digits by 1 and replace the hundreds, tens, and units digits by 0. You result will end with (t+1) 000
Note if (h+1) or (t+1) give you 10, put a zero at their positions and increase the digit to the left by 1.
Example. 78997 to the nearest hundreds 78997 becomes 789(9+1)0 or 78(9+1)00 or 79000
May 22, 2014 | Casio FX-115ES Scientific Calculator
Round to nearest hundred thousand
Round what to the nearest hundred thousand? On what make and model calculator?
Oct 18, 2013 | Office Equipment & Supplies
Alice said that 3,642 rounds to 3,600. Ned said it rounds to 4,000. Who is correct
They both are. 3,642 rounded to the nearest hundred is 3,600. 3,642 rounded to the nearest thousand is 4,000. Rounded to the nearest ten, it's 3,640.
Sep 19, 2013 | Dainese Alice Lady Textile Jacket Highrise
I need to round 301,421, 900 to the nearest hundred thousand can you help me?
Aug 19, 2010 | Casio MS-80TE Calculator
281 people viewed this question
k24674
jasbo
jasbo
