Question about Garden
Engine turns over but will not start
Replace coil, replaced fuel solenoid and verified spark at plug. Nothing
    Top Expert:
  • 10,875 Answers
Unplug the ground from the coil,if it starts then safety switches are bad
Posted on Apr 23, 2015
    Habit-Forming:
    New Friend:
  • 41 Answers
Check the safety switch under the seat, make sure the wires have not come loose and check the switch with a meter
Engine has been rebuilt, has now been stored for over three years. I have just put it all back together properly and can't get it to start. Searching for an appropriate wiring diagram for this model or any...
take out the spark plug keep it in the plug wire turnover the motor with the plug grounded against the head but do not touch the end of plug an turn over motor it should fire at the plug tip.If no fire check the coil gap and safety switches.Hope this helps.
Mar 21, 2015 | Garden
When I turn the key on I can hear fuel pump prime and from some where around the carburetor I hear a buzz noise.
Make/Model/Year helps get a more specific answer.
However, that buzz noise around the carburetor may be a fuel cutoff solenoid.
Note: On Riding Mowers if battery voltage drops below 9 volts when cranking or while the engine is running, the fuel solenoid will not function. That means the engine will not start or will die soon after starting.
  1. verify battery fully charged.
  2. verify the fuel cutoff solenoid clicks when you turn the key switch.
  3. Check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells.
If the problem is not the fuel solenoid you will have to go step by step through the fuel, fire, and air diagnostics. Here is the routine we use on riding mowers.
For a more precise answer we need Make/Model/Year/Engine Model/Deck Size, and hours on meter if you have one.
Let's say you have less than 300 hours on the engine. Let's further assume it worked last summer, or last week, but now it's acting up. Let's also verify the battery is in good shape and fully charged.
A mechanically functional (meaning all the internal parts are working, i.e. pistons, valves, etc) engine requires 3 things, air, fuel, spark. So the quickest way to start your diagnostics is to remove the cover over the air filter and then remove the air filter. I do not recommend spraying Quick Start.
  1. remove air filter (set it aside for the rest of the diagnostics)
  2. put throttle on fast run (do not choke)
  3. pour an ounce or two (a shot glass) of fresh gas into the carburetor
  4. crank engine (15 to 20 seconds, rest to cool the starter, repeat 3 times if it does not fire at first).
Removing the air filter and placing the throttle at full speed with no choke eliminates the "air" question. Dumping in the fuel eliminated all fuel related questions. What's left? Spark. If the engine fires and runs a bit, then dies, you have eliminated the spark question. The engine started so Spark and Air are good; you have to track down a fuel problem.
If the engine does not fire, you have eliminated the Air & Fuel questions; you must tract down a Spark problem.
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank.
  2. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. If it does not, remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out blockage inside the gas tank. Once you have fuel flowing out the line to the filter, PUT ON A FRESH FILTER. Try cranking the engine. If it still does not start move on to the carburetor.
  3. Note: many systems have a fuel shut off solenoid. This is a small black cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on.
  4. NOTE: if battery voltage drops below 9 volts when cranking or while the engine is running, the fuel solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good and the voltage is still dropping you may have a bad starter motor and it is drawing too much amperage.
  5. Ck to see that the carburetor bowl is full of fuel, if not...you may have to disassemble and clean the carb at this point.
Tracking down Spark problems.
  3. get fresh spark plugs and verify gap
  4. install plugs and crank. Perhaps verify spark with a spark tester.
If these simple steps do not solve the spark problem, you have a Spark problem that moves into the arena of complex. You will need to check coil gap and coil performance. If it still doesn't start you will need to diagnose the electrical system for wiring and safety switch problems, key switch problems, fuses, etc.
A Problem of Air Control.
If you determine the Spark & Fuel systems are good, the next likely problem is Valve adjustment out of wack. This is a problem of Air Control (and its sister compression), the third element in the engine trinity. Usually this problem shows up as backfire; either back through the carburetor or out through the exhaust. It will backfire while you are trying to start it. HOWEVER, it does not always generate backfire. You may instead notice that the engine spins more freely than usual; or oddly enough just the opposite and the engine bind while you are cranking it. This is because the compression is lost by out of wack valves or the compression is out of sync with the spark. You need a valve adjustment.
Once you get it running be sure to replace the Air Filter with a new one.
These simple steps solve most starting and running questions and problems.
Mar 19, 2015 | Garden
120john deere wont start seems like its not getting fuel will start withquick start
More and better information will help you get quicker and better answers. I will assume you are asking about a JD LA120 or D120 or L120 or perhaps even an X120. However, these models do not have fuel injectors.
Many things to consider but, let's try the simple things. You didn't say, so I am going to assume the mower is at least newish, not 30 years old. Let's say you have less than 300 hours on the engine. Let's further assume it worked last summer, or last week, but now it's acting up. Let's also verify the battery is in good shape and fully charged.
  3. pour an ounce or two of fresh gas into the carburetor
Removing the air filter and placing the throttle at full speed, no choke, eliminates the "air" question. Dumping in the fuel eliminated all fuel related questions. What's left? Spark. If the engine fires and runs a bit, then dies, you have eliminated the spark question. The engine started so Spark and Air are good; you have to track down a fuel problem.
  4. NOTE: if battery voltage drops below 9 volts when cranking or while the engine is running, the fuel solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good and the voltage is still dropping you may have a bad starter motor and it is drawing to much amperage.
  5. Ck to see that the carburetor bowl is full of fuel, if not...you may have to remove, disassemble and clean the carb at this point.
  4. install plugs and crank.Perhaps verify spark with a spark testor
Mar 10, 2015 | Garden
Cold start will run short time then die battery not strong enough to realy spin moter
My d100 will not start
Check for good , strong spark. Take spark plug out and ground the outer core of the plug to the engine. Hold the plug with a pair of insulated pliers. Have someone crank the engine while you observe for a good strong blue spark. If the spark looks nice and bluish, then next would be to clean the carburetor. I suggest trying a "quick clean before taking the carburetor bowl off. Take spray carburetor cleaner and spray inside the carb throat with the air cleaner off. Also take about 1/2 can/bottle of fuel line injection cleaner and put it in the gas tank. Then try starting the mower. May sure the gas in the tank is fresh.
Jun 20, 2014 | John Deere Garden
I HAVE FUEL, COMPRECION AND GOOD SPARK, BUT WHEN A CRANK THE ENGINE IT TUNS BUT IT WONT RUN,
Feb 11, 2014 | John Deere 22HP VTwin 48" Riding Mower
Craftsman YT 4000 Won't Start
Did you check for "spark" at the plug? Check fuel filter ( maybe plugged up ". How fresh is the gas?
Nov 10, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
When I go to start, it turns over but will not start. replaced fuel pump, but did not help.
Check your starter solenoid, (put key in run position and use a jumper wire to make contact to the two large terminals) if it starts replace the solenoid, located on the inner fender well. If there is no difference then replace the ignition module.
Feb 16, 2011 | 1991 Ford F150
1989 astro van turns over will not start seems not getting fuil gas tank full
#1 NEED TO VERIFY SPARK AT SPARK PLUGS # 2 CK FUEL PRESSURE AT SCHRADER VALVE ON FUEL RAIL ,,PRESSURE DEPENDS ON TYPE ENGINE ....IF NO SPARK AT SPARK PLUGS CHECK SPARK FROM COIL WIRE , IF NO SPARK AT COIL ,CHECK VOLTAGE TO IGNITION COIL SHOULD BE 12 VOLTS, IF NO VOLTAGE AT COIL ( KEY ON ) CHECK FUSES THEN IGHITION SWITCH. IF NO FUEL PRESSURE AND FUEL PUMP RUNS REPLACE PUMP .. CK VOLTAGE TO FUEL PUMP WHILE CRANKING . CK USING PUMP GROUND WIRE AT THE PUMP CONNECTOR THIS WILL PROVE GROUND ALSO. USE TEST LIGHT TO VERIFY
Aug 07, 2010 | 1989 Chevrolet Astro Cargo
Honda Engine on my Troy-Bilt 834 wont start
Check the engine coil sounds like it is either bad or ground wire is not going to start check by removing the wire from the coil if it starts fix the brake ground if it does not start the coil is bad replace coil.
Oct 10, 2017 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
