Question about Volfenhag Car Audio & Video
How do you replace fan inside volfenhag 1000 watt amp
What speakers I can wire to my amp? a volfenhag zx-8200 1000 watt amp. Currently 800 watt bose sub bridged to it, capacitor as well. and a 150amp circuit breaker. I have a 14 volt 105 amp alternator.
1. It depends on how many and what type of speakers you run.
It is a 'bridgeable' amp and therefore has a variable number of configurations.
You can run that Bose sub on one channel and twin up. It's not a great idea to have the drivers max near or lower than the output of the amp and puts out serious thump from a 30W cone.
Jan 15, 2017 | AMP Car Audio & Video
I have a 2000 w volfenhag amp and a 15 in cadence 350/600 rms watt sub, what gauge wire should i use?
I would use a 4 gauge wire for the power supply to the amp and a 4 gauge neg of the amp
Jun 25, 2016 | Volfenhag Car Audio & Video
How much can my speakers handle?
As a rule of thumb you should drive them before their clipping or start to distort point, hope this helps.
Sep 15, 2013 | Volfenhag ZX-5168 2-Channel 4000W...
How to install a zx-hypercap in to my car
Hello youngbossrio,
Like other car audio capacitors, the Volfenhag zx-hypercap has two terminals, a positive and a negative. The negative terminal is connected to the metallic frame of the vehicle (ground). The positive terminal is connected "in-line" with the amp 12V positive terminal.
The capacitor should be as close as possible to the amp. Within a couple of feet is acceptable.
The capacitor needs to be "charged" before connecting it directly to 12V positive. This is done with a 1000 ohm resistor and a voltmeter. The exact value of the resistor is not critical but it should be in the 500-1000 ohm range. Use at least a 1 watt resistor (your capacitor may have come with a resistor for charging).
Hope this helps.
Aug 26, 2009 | Volfenhag ZX-8300 Car Audio Amplifier
I have two volfenhag 1000 watts speakers
If you are looking for some serious sound try using a Rockford Fosgate P3001T Amplifier.. it pushes 3000W Max its a 4 channel amplifier. Or you could go with something small. I have two JL Audio 10s in my car running with a 600W 2 Channel MTX Amp.
Apr 03, 2009 | Volfenhag ZX-4812 Car Subwoofer
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Amp not working
if your light is not coming on then you probably dont have power to it. check all your connections and make sure it is all hooked up right. check the remote with in the back of the deck.
Jul 24, 2008 | Volfenhag 1000 WATT AMP 4 CH AMPLIFIER...
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Car Audio & Video Logo
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Electro Med Services...
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
