Question about Garden
Fuel mix for older saw? - Garden
  • 2,760 Answers
Prior to 1978 its 50/1 from 1978 to about 1994 its 40/1 and after 1994 it's 35/1 till 2010 (no oil) its 4 cycle now these values were set by the EPA to the national forestry service on small engine emissions in forests
(where chain saws are used)
but generally speaking the more oil you can get to run in your saw the better it will be on it , all depends what it will cold start with in its; tank ?
Posted on May 20, 2015
2 Suggested Answers
Editor925
  • 285 Answers
SOURCE: proper fuel mix for chain saw
16:1
Posted on Mar 19, 2009
Is this a 2 or 4 cycle and whatis the correct oil mix?
I guess the first question is what machine is it? Most chainsaws are 2 stroke and need a fuel / oil mix. If the machine is lesst than 5 years old then a mix of 50 parts fuel to 1 part 2 stroke oil is likely to be needed. Older saws often used 25 parts fuel to 1 part oil. From experience I find that 50 to 1 on the newer saws is too little oil and use a 40 to 1 mix to avoid the expense of having to replace pistons and cylinders!
Sep 23, 2015 | Garden
What petrol mix does it use, and what type of oil
Depends on what type of saw it is some very new ones use 50:1 oil fuel mixture older ones use 25:1 mix and the larger the bore or engine capicity you should probably use a little more oil to protect it, Mose saws will give the oil fuel ratio on the gas cap or in the owners manual
Brad
Aug 01, 2011 | Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
I cannot locate my owners manual and have not used the Homelite Ranger 16 inch in quite some time --- What is the fuel and oil requirement??
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
Jan 19, 2011 | Homelite ZR10926 16 Chain Saw
Was is the fuel oil mix for the husqvarna chainsaw
It depends on the age of the saw, you can use a 20 to 1 mix on the older saws,or the newer saws only use a 50 to 1 mix.
Nov 03, 2010 | Husqvarna Garden
Fuel mix
Quick check with mfg (DAGS mcculloch) yields: 40:1 with their 2-stroke oil and 87 octane.
I've run one (with 14" bar) for years on same 50:1 mix I use in other saws with no problems- synthetic oil and regular gas. One of these saws is now 30 yrs.old. And ... no smoke-cloud, nor port/muffler mung.
With new saw, you might want to use more oil for first few hours. Just remember that doing so leans the fuel mixture.
Aug 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Will start but will not stay running poulan 2000 just changed spark plug thought it might help also have a 2300 will not take gas to carb just changed the fule line
Check the diaphragm in the carburetor of each saw for hardness or cracking of the material. This is a common problem with older saws, but easily fixed by replacement. Check the fuel filter within the tank of each saw for being plugged--a problem that occurs when leaving old fuel mix in the tank for long periods. Hope this helps!
Jan 24, 2010 | Poulan Garden
Unleaded fuel put in chain saw. Saw still working but I have lost the manual and don't know what to do or the correct dilution for oil/fuel mix.
I am not sure what your trying to get at put if it is a new saw they run fairly lean 50:1 but older saws run at about 20:1
Hope this helps, don't forget to rate.
Sep 03, 2009 | Garden
Blown engine
makita likes you to use at least 91 octane fuel and a synthetic oil mixture. the stens oils is garbage, i switched to the makita oil around 6 months ago and i havent had a problem. also, the wacker saws use the same motor and their piston heads are sleeved in carbon so they last longer and dont score the cylinder as fast as the stock makita heads.
makita also makes a 100:1 mix hi performance oil you can use.
Oct 30, 2008 | Makita DPC8112 16" 81CC Gas Powered Power...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
