Question about HP Computers & Internet
An HP Media Center PC stuck in analog mode.
I have an HP Media Center PC connected to a Dell monitor (that works in my Dell computer), but it shows "Auto Detect: Analog Input" and then it goes to sleep right away. This computer in question worked very well. I recently moved and had it unplugged for a couple of months. Is this fixable? Any help would be much appreciated! Cheers, Dave.
  • HP Master
  • 3,320 Answers
Sounds like the cable has a broken lead or a damaged pin. Try a different cable.
Posted on Apr 23, 2015
Testimonial: "Sorry, tried that as well. Thank you for your help. Cheers, Dave."
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Gateway computer is stuck in power saving mode.
The Gateway 818GM is a few years old but if - hopefully - the motherboard auto-detects a video card, try removing the MSI MS-8936 video card & swapping over the monitor lead to the other VGA connector fed from the motherboard.
Failing that, if you think it's a faulty video card, they're cheaply available on eBay eg for US$6.70 here:
MSI NVIDIA GeForce MX 4000 MS 8936 64 MB DDR SDRAM AGP 4x 8x Graphics
Feb 21, 2014 | Dell Dimension 3100 PC Desktop
Monitor in power save mode and will not restore a picture.
Check all your video cables and check your keyboard and mouse cables. If everything is ok, reboot computer.
BTW - What color is the power indicator?
Jun 27, 2012 | Dell Dimension 8400 PC Desktop
Installed a Graphics card EVGA 6200 AGP 8X in my PC HP Media Center PC m370n now keeps showing failure notice
Did you install the drivers for the Graphics Card before you plugged the card into the computer? If not, remove the graphics card and reboot using your old video connection, install the driver then install the card and plug your monitor into the newly installed card. If you still have an issue try booting into safe mode.
Mar 19, 2012 | HP Media Center Photosmart PC (M7160N) PC...
Message on monitor says " no analog signal".
If you are getting no post display on boot up (dell spash screen, and windows loading screen):
First step is to plug a different monitor into the computer. If this works you most likely have a bad monitor. If not then it is a hardware issue with the video card on the computer.
If you getting the post screen then you may have your resolution set to high, boot in safe mode (F8 on the key board right after the post screen) and chose safe mode. once windows comes up, right click the back ground and chose a lower resolution setting.
Hope this helps
Oct 17, 2011 | Dell OptiPlex GX620 PC Desktop
Lg monitor - ''Analog Power Saver Mode''
Kindly check the power supply inside your system, when you power on does the fan rotates. if not then you need to replace the power supply of the system.
i hope this will resolved the issue
May 25, 2010 | Computers & Internet
Dell c521 seems to be wil not launch
Try to completely turn off the computer by pressing and holding the power button for at least 4 seconds. Disconnect it from the mains, wait for a few minutes and the connect and try to power on. If this alone helps, you might be right that it is not properly being awaken from sleep mode. If so, check your settings in Windows and perhaps look for the newest drivers here. See to it that you have the latest Windows updates as well. If you are using Vista, this is a common problem prior to Service Pack 1, so you would want to download and install SP1, if this is the case.
If you don't succeed with the first solution, you might have a more severe problem.
Depending of the configuration of your machine, you might have an internal graphic solution or as an add-on card. Connect the monitor to the appropriate connector on your computer. Make sure that you only use EITHER the digital OR the analog cable, and not both at the same time.
Good luck, and let me know if the above is helpful or not so that I might research some more.
Apr 26, 2009 | Dell Dimension C521 PC Desktop
My monitor says "analog saving mode" it won't do anything else!!
Check the connections between computer and monitor if you have another monitor try it and see if it works. I know if my monitor is on but not connected to my computer I get a smiler message. Larry
Mar 08, 2009 | HP PAVILION A6230N DESKTOP PC
Floating window
HOW MUCH MEMORY DOES THIS COMPUTER HAVE
THIS COULD BE THE PROBLEM DO YOU EVER GET VIRTUAL MEMORY ERRORS
Jan 14, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
