Question about Acer 23" HD LCD Touchscreen 4GB RAM 1TB HDD Desktop Computer (5889124)
Image doesn't fill the entire screen - Acer 23" HD LCD Touchscreen 4GB RAM 1TB HDD Desktop Computer (5889124)
  • Acer Master
  • 5,631 Answers
Check the PHYSICAL controls of your monitos, normally you should have some buttons on or under the frame. Set for 9/16 size
Some monitors can be set using a remote
Posted on Apr 23, 2015
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Tip
Projection Screen Tip #2
Make sure that the screen is the correct aspect ratio for the most commonly used projection device. For instance, a video projector should be in 4:3 or 16:9 modes, depending on its native aspect ratio. The screen should match the aspect ratio that is used most often. This will allow the entire screen-viewing area to be filled by the projected image.
on Aug 16, 2010 | Office Equipment & Supplies
The picture doesn't fill the screen.
Well this may indeed just be a setting, you need to look in your manual, with regards to Aspect Ratios and Screen Sizing. There are screen adjustments that can be made to make the image fill the screen. However the actual way in which it is done is individual to each unit.
Jul 05, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
MY IMAGE IS NOT FILLING UP MY ENTIRE SCREEN, THERE ARE BLACK MARGINS ON EITHER SDIE OF THE PICTURE HOW DO I MAKE MY IMAGE BIGGER
well if you cannot ZOOM it from the screen settings in menu then I suspect your flyback transformer or the transistor that controls screen width and convergence is faulty.
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Computer does not display full screen
Check your desktop display settings. Sometimes programs change this and uninstalling or going to to another start point doesn't help
May 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen is stretching on each end. Vizio 32 inch. The picture is stretched on each end. The picture looks real weird and it almost makes you dizzy when you look at it.
Sounds like the display is in a mode which is sometimes called "Horizon", where they seek to fill the entire 16:9 screen with an image which is originally 4:3 by leaving the center of the image mostly alone and stretching the ends out horizontally. If your remote control has an "Aspect" button you might try pushing that a few times to cycle through the various settings.
Oct 10, 2009 | Vizio Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
My new Samsung LE32R88BD was showing a pixellated picture on movement, but it filled the entire screen. Since switching my Virgin box through HDMI, the picture is less pixellated but I cant get the picture...
I did some reading on the net, try to "calibrate the screen". Try set the input to 1080i, then run the thx optimiser to give you a starting point, then try a bluray with a bright image.
Keep replaying the same chapter and try raising and lowering different settings. you may find that your brightness is set way too high and after dropping it from 90 to 29, you may find that detail will have crept into the image. Try giving the colours a boost as well.
The detail in HD is very subtle, and having a properly calibrated screen will make all the difference. So to answer your question: set your input to 1080i, make sure your HDMI is outputing RGB and start tweaking that screen!
Mar 08, 2008 | Televison & Video
Screen Problems
Has the TV been dropped lately? If so it's possible the coils that guide the electron beam are misaligned. Also many tv's (same for computer monitors) have either manual knobs or firmware controls that allow you to position your screen and adjust height, width, etcetera..
Dec 28, 2006 | RCA T19408 19 in. TV/VCR Combo
Acer 23" HD LCD Touchscreen 4GB RAM 1TB HDD Desktop Computer (5889124) Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
