Question about Bella 12-Cup Programmable Coffeemaker
. Loved this product and it stopped working after one year.
Model CM4296 - Item 13879
I want to change my power suply,mine has got very noisey over the last year, works fine but noisey please reconmend a good up grade make and model or severial 450 to 800 watts I have the medion m3 composer...
Corsair 550VX (550watts and in my opinion the best PSU in it's class)
Or Corsair 450VX which is a 450 watt version and probably more than you need but not over-kill either. I have used a 450VX in my own system on a Quad Core 125 watt AMD Phenom Processor, 3 hard drives, 8 USB Ports, 5 case fans, 2 DVD burners, etc.. without any problems for years. They are guaranteed for five years from the manufacturer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
Jan 03, 2011 | Medion M3 Composer 5200 PC Desktop
Remington 14" electric chain saw (model 075762J) does not get sufficient electric power to rotate
I went here and entered your model number.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
Clicked on the "IPB" link and found
Item 3 - Armature, pn 100933 $60.34 BackOrdered with no delivery date.
Item 9 - Field, pn 098042-01 $48.76
Item 4 - Bearing, pn 075676 $5.60
Item 10 - Gear, pn 059606 $7.25
Item 11 - Internal Gear, pn 107713-01 NoLongerAvailable.
I would inspect Item 11, I think you will find it failed and is not allowing the motor to rotate. It is also likely the brushes (part of Item 9) have worn away. Least likely is Item 3 is defective. Your unit is either not repairable or will cost in excess of $50 to repair. You can try an Internet search for any needed parts not available at RemingtonPower, we can do no more.
RemingtonPower has stopped all production. Many replacement parts are no longer available. If you can repair it today the next time parts are needed e-Bay may be the only source. I recommend you apply the money toward replacement with a name brand unit you expect to be in business for 10 years or more.
Please do not punish me because you are unhappy with RemingtonPower. I provided a very good answer; although probably not what you wanted to hear. HTH
Lou
Dec 18, 2009 | Desa International Remington 14" Electric...
My DVD stopped reading my program CDs.
Honestly, if its not under warranty, you can buy a brand new DVD Burner for cheap.
Look here: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136144
$24 for a new drive
Jun 22, 2009 | E-Machines eMachines Refurbished EMA...
Having trouble registering product
Try Black & Decker Tools. From there you can be directed to a link to register your item. Have the item name, model number, serial number,purchase date, where you purchased it, and any other info related tro your product. This should be all you need.... NOTE.... You may have to create a user ID and a Password to do this...If all else fails ...call the toll free nuber on your registration paper work.....SOMETIMES it is great to have a person to person conversation...at no cost to you as it is a toll free #.....Happy New Year....Joe
Dec 30, 2008 | Black & Decker Black and Decker Cd9602k...
I need to update maps on nuvi 350
Download new maps from eMule. Problem solved ;-)
Dec 18, 2008 | Garmin nuvi 350 GPS Receiver
Black and Decker 5 cup coffee maker, model DCM675BMT
the thermal overload may have opened. Unfortunately, they are single use items. Open up the unit and check the overload, usually a small item with two wires attached to it. this item would be fastened to the heating element. I save broken coffee makers and salvage the overloads in case I need one later and have replaced several over the years.
Sep 17, 2017 | Black & Decker DCM2775
Bella 12-Cup Programmable Coffeemaker Logo
Top Bella Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Kolbrun...
ray gallant
Are you a Bella Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
