Question about Garden
Water is gushing out the lid and no water going into the pond the pump is working
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 19 Answers
We'll probably need a little more information about what equipment you're using and what the setup is. In the meantime, check that all the right valves are open and all the wrong ones closed. Also make sure you have removed all packing materials - some pipes/hoses are fitted with end caps to avoid dirt getting in before you set them up. Also make sure you haven't got some mud or slime blocking the outlets. Have you got the outlet connected where the input should be and vice versa? (Sorry to ask, but we all do stuff like that now and then ;) )
Other than those, the most obvious thing would be that you have an airlock somewhere. If you can, try to fill all the lines with water before switching on the pump.
If none of that works, come back with more info and we'll do our best to help. Good luck.
Posted on May 15, 2015
Bloomingidoi
  • 49 Answers
SOURCE: Pond pump not working
Well first thing is to locate pump and then check to see if the screen is plugged. turn power off and check inlet tub of pump for sticks, rocks,or leaves in it that can plug the suction on it
Posted on Nov 28, 2008
pondking
  • 21 Answers
SOURCE: I have versa gold submersible
Intermittent running usually points to intake or impeller obstruction. Remove the impeller screen and cover, inspect the impeller, the screen the discharge exit point for debris. Unlike other brands the impeller is not replaceable if worn or damaged.
Posted on Mar 05, 2009
SOURCE: Pump just stopped working one day. It was working fine the day before. Hums when submerged but does not pump.
It sounds like your filter is plugged, Take the filter cover off and rinse out your filter, it should take care of the problem. I clean my filter out every 2-3 days.
Posted on Apr 28, 2009
  • 10865 Answers
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
Posted on May 02, 2009
Healeyman
  • 1198 Answers
SOURCE: The motor runs, but not take in the water
Check the strainer at the pond. Prime the pump and see if it pumps anything.
Posted on May 04, 2009
Prime the pump
see the FIRST in red under the STA-RITEremove the lid fill the pump up with about 3 gallons of water then replace the lid and start the pump. should start to flow in about 1 minute, if not repeat priming procedure
Jul 19, 2012 | Sta Rite Industries Shallow Well Jet...
The pump lid has water coming out of it. is that normal? pump was off but water was gushing out when I opened it to put chlorine tablet in filter
Pull the lid back off and check the O-ring...it is not seated properly...reinstall the lid and you will be okay...
heatman101
Jul 13, 2010 | Intex 15' X 42" Easy Set Pool Complete...
I don't know what's happening - the pump & filter seem to be set up properly but when I take the lid off the filter to dump the basket, water comes gushing out of it and doesn't stop. The filter is...
It definitely sounds like your pool filters not set up correctly. Here is a copy of the users manual. Try taking a look at the detailed drawing. It sounds like your valve might not be set up correctly so pay special attention to that area of your filter.
http://www.backyardcitypools.com/images/bwp/carefree-manual.pdf
Jul 07, 2010 | Waterway Twm Above Ground Pool Pump and...
Question before purchase (existing pond)
You don't need a bulkhead if your liner is EPDM. You can use a boot that is attached with adhesive that will seal you pvc piping. I don' t see a problem with dirty water going thru the pump before the filters. for some diagrams of settling tank installations see:
http://www.koipondfiltering.com/koi_pond_filters_diagrams_intermediate.html
Jan 24, 2009 | Tetra 16361 Vacuum Bottom Drain Portable
PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Jan 09, 2009 | Little Giant Opwg 71 71 Gpm Out of Pond...
Filter
You can build your own little filter by placing is in a container, like yorgart, with lid, but before you do punch holes into it no more than 1/8 inch all around. the more holes the better. this way your pump does not **** something into the chamber that will stop the propeller. I have done this and it works like a charm. Also you can use pond pots, the ones that have many slits in them.
Magnetic Drive Pond pumps can be left in the pond even if it froze. These pumps are great for weather. Once water unfreezes, pump will start again.
Jan 04, 2009 | Sti Group Sti Infinity 160 Gph Magnetic...
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Garden Logo
273 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
