Question about Garmin GPS
I downloaded the Garmin Express for updating my Garmin but when I connect my computer to my Garmin it freezes. Does anyone have any suggestings as to what to do to update my device?
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
My guess is the Garmin Express did not download properly
You should uninstall and delete the app and download again
Posted on Jun 06, 2015
SOURCE: Garmin Nuvi 310 D
You can lift of the grey trim on the front and then hold down the reset button might not work though but its worth a try.
Posted on May 04, 2007
SOURCE: No Product Key to complete Garmin c330 update download
If you purchased the DVD Update version, the Product Key that they are requesting is on a label on the back of the DVD case that contains the update DVD.
If you downloaded the update they were supposed to e-mail you the Product Key.
Posted on May 16, 2008
SOURCE: 2009 map update for garmin c330 street pilot
Perhaps your are using a low speed USB port. I once use the low speed USB and does not work. This unit only works in high speed USB. Hope this will help.
Posted on Mar 10, 2010
  • 54 Answers
SOURCE: My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
Posted on May 03, 2010
tunde007
  • 2382 Answers
SOURCE: I have a Garmin 1490t.
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go tohttps://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Posted on Oct 09, 2010
Have free lifetime updates but got a new computer. How do I download the garmin website again?
Install the Garmin Express that is found on the Garmin website. Once installed, connect your Garmin to your PC and Garmin Express will detect your GPS and let you choose any updates available for your GPS.
Mar 15, 2017 | Garmin GPS
HOW TO GET MAP UPDATE
Download Garmin Express to your computer. Connect the unit via USB cable. Register the unit and then do the updates. You can get unlimited lifetime updates which is the best value.
http://software.garmin.com/en-US/express.html
May 03, 2016 | Garmin nuvi 265WT Car GPS Receiver
The screen is frozen with the Garmin logo.Turning it off and on does not help.Suggestions?
The older ones have a small reset button on the back. If no button, connect it to a computer and download Garmin Express which is the updater program.
Nov 05, 2015 | Garmin nuvi 1450 GPS Receiver
How do i reset my garmin nuvi 200w satnav it says no detailed maps found how can i reinstall them
Locate the reset button, located on the back of the device, in the lower left corner. Remove the sticker covering the button, and use a straightened paper clip to depress the tab.
To reinstall maps
Connect your Garmin Nuvi to your computer via USB cable. You can only update the maps through connecting to your computer.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
heres a link to the site;
http://my.garmin.com/mygarmin/login.htm.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
Close Garmin Express and unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
If you weren't automatically prompted to install Garmin Express, you can download it from
http://software.garmin.com/en-US/express.html.
Jun 06, 2015 | Garmin nuvi 200W GPS
How to update garmin Niuive 650
Hello
Download the Garmin Express application
The Garmin Express application is used to update maps and device software on compatible GPS devices.
Install the application on the computer
Connect a compatible Garmin device
Navigate the on-screen prompts
The Garmin Express application will update the maps and / or software on the device.
May 17, 2015 | Garmin GPS
Time to update material, have added 8 gb memory card how do I download
The Garmin Express application is used to update maps1 and device software on compatible GPS devices.
Install the application on the computer and connect your device to the computer
May 06, 2015 | Garmin Nuvi 1450 - Gps Receiver
Added memory card 8GB want to update GPS
May 06, 2015 | GPS
How to update
May 06, 2015 | GPS
When trying to put in an address the Garmin asks me for a country and then does not accept it after typing in the first letter. The other functions appear to be ok.
Hello
Purchase your map updates (if necessary). You can purchase map updates for your Garmin Nuvi from the Garmin website. There are two basic options: a lifetime purchase or a one-time upgrade. The lifetime purchase gives you access to any new updates for the life of your device, while the one-time upgrade will provide you with the latest current maps, but you'll need to purchase again if you want to upgrade again later.
Make sure to log in with your myGarmin account before purchasing the map upgrade.
You can download garmin express here
Apr 19, 2015 | Garmin Nuvi 610 GPS Receiver
Trying to connect to garmin.com/us
The GPS itself will not connect to anything - you need to connect it to a computer (that is connected to the internet) via USB cable and then run Garmin Express software from Garmin. The Garmin Express software will alllow you to update maps, firmware and more. The Garmin POI Loader software allows the transfer of customized POI's (Points of Interest) such as geocaches, etc. Check the links below for these offerings.
Garmin Express
Updates Downloads
Mar 23, 2015 | GPS
GPS Logo
116 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
