Question about Honda Generator Owners Manual Em1600x Em1800x Em2200x
I have a Honda EM1600x and the engine runs great, except i can't get any electricity out of it. It's been stored outside for a couple of years now and i have no idea how to get it working. Any help?
If it has brushes they can become stuck, I had the same problem and after some gentle tapping around the generator it started producing voltage again.
Posted on Apr 26, 2015
    Top Expert:
  • Honda Master
  • 10,875 Answers
It is full of rust and an extensive overhaul is needed call a generator dealer for info
Posted on Apr 23, 2015
  • Honda Master
  • 1,169 Answers
Rotor probably needs reflashing as they do lose their magnetism when in long term storage.
Testimonial: "how do you reflash it?"
  • Eugene Rounds Apr 24, 2015
    Sorry for taking a while to reply been in the shop most the day. I also wanted to consult the wiring diagram. 1.First find the rotor brushes and disconnect and insulated the one closest to the bearing. 2.Now using a 12v battery. Connect it to the brushes with the positive lead on the brush closest the the bearing. 3.Start your generator. 4.If it was only needing reflashing it should be generating power again. Run it a minute or two and shut down. 5.Disconnect the battery and reconnect the brushes as normal and retest. 6.If was generating power with the battery connected and now it won't then the it is mostly the AVR (autoimatic voltage regulator) is bad. 7.If it doesn't produce power with battery connected then further tests would need to done but it does get expensive to repair from here.
    Problem Solver:
  • 41 Answers
Hi have you check the circuit breaker ?
Testimonial: "Yes, i just checked it with an ohm meter and it said it the switch wasa good. Any other suggestions?"
  • Catalin Muresan
    Catalin Muresan Apr 25, 2015
    I will say Eugene have right if no power with a battery conected then may need a new generator stator on your engine and that it isn't cheap
  • Catalin Muresan
    here is a easer way to flash it with a drill www.youtube.com/watch?v=-LR62sm7USU
How can I diagnose the problem with the indicator light flashing after supplying power for only a minute?
a problem has arisen in the converter panel /board
take it in for a proper diagnosis and repair
Apr 20, 2016 | Honda EB3000C CYCLOCONVERTER Generator -...
My EB2200X generator won't generate electricity
Check output on diode pack on the back of genny maybe stuck or brushes need replacing.
Oct 15, 2014 | Honda Em1600x, 1800x, 2200x, Eb2200x...
Random no start 94 accord swapped in h22a
u sure its electrical--may be fuel system--many times the computer dozint recognize a new engine--may need to get it flashed or reprogrammd--dont replace anymore parts save ur $$
Dec 13, 2012 | 1994 Honda Accord
92 honda civic wont start
You need to run a system fault code test, do that by following the instructions HERE, code are also listed at the site.
Oct 02, 2012 | 1992 Honda Civic
Honda EM1600X generator - Motor runs good but no power
check the avr / brushes if it has them
if not
check diodes on end of armature and capacitor
Mar 17, 2010 | Electrical Supplies
90 Honda Prelude misses sometimes
Maybe the crank speed sensor is faulty - would confuse ECU and show wierd rev counter results. Any engine check-light (MIL) or stored error codes?
Jun 09, 2009 | 1986 Honda Prelude
Honda cb750 f2 1978fault on old bike ! electrical problem
From your explanation it sure sounds electricals, but surprising to hve a total failure to the electricals and thn it reappears after 30seconds!
Best would be to go through the wiring especially frm the battery onwards, the fuse box .
Since it is totally disappearing it should be a fault to those main wires could be lose connections somewhere!.
Hope this helps.
May 08, 2009 | 1992 Honda CB 750F2 Seven Fifty
HONDA CIVIC ESI ENGINE WON'T RUN
He is probably messing with the main relay its a grey box under the dash near the fuse box if you look up under the dash you will see it they are know for going bad if you tap it a couple of times while cranking the car and it starts then replace it they are not that expensive
Apr 26, 2009 | 1993 Honda Civic 4 Door
Honda Generator Owners Manual Em1600x Em1800x Em2200x Logo
190 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
