Question about Maytag Dishwasher
How do you reset Maytag dishwasher model # MDB7749SAW1
When I select-press the (wash cycle) the display will switch over to the the rinse cycle only.
SOURCE: Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Posted on Jul 03, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
SOURCE: Dishwasher only runs in rinse only mode!
my dishwasher just keeps bleaking clear AND NO WATER IS GOING INTO THE MACHINE IT JUSTS KEEPS RUNNING BUT THEIR IS NO WATER COMING IN.
THANKS
Posted on Nov 18, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
SOURCE: Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Posted on Dec 28, 2008
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Blinking "Normal" light on a Maytag model
    Hi
    Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
    Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
    Hope this helps... Please post back if you need more information.
    Daniel
    May 19, 2011 | Maytag Dishwasher
    My dishwasher is brand new and is not drying the dishes!!! they are still wet. the model number is she55mi 2uc/60
    If you are using a quick cycle there is not a dry cycle included due to the short wash. Ensure you use rinse aid even if you are using a product that includes it, as this assists the drying cycle by breaking the surface tension of the water and allowing less water to 'stick' to the load. Check that you have the machine set to the use the rinse aid and that the intensive dry is on. This can be done by following the instructions in your manual.
    Extra Dry Heat
    With this option you can raise the temperature of the rinse water and increase the drying time for improved drying.
    This option is only for units with a display. If your unit has a display window, please follow the instructions below.
    NOTE: The unit must be powered OFF before activating.
    To activate:
    Press and hold the left "Cancel Reset" button, then • press and hold the ON/OFF button.
    The model number I think should read SHE55M12UC/60.
    I hope this helps.
    When the LED display window indicates a "0" or "1" • release both buttons.
    To activate extra dry heat, press the left "Cancel Reset" • button until the display indicates "1".
    To disable extra dry heat, press the left "Cancel Reset" • button until the display indicates "0".
    Press the ON/OFF button to save the setting.
    Jul 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
    Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
    Hello and welcome to Fixya,
    I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
    I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
    TO OPERATE:
    First depress the On/Off Button until it locks in place.
    Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
    To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
    The Cycle Countdown will display an approximate run time for the cycle chosen.
    This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
    Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
    At the end of the cycle the display will show a CL, indicating that the cycle is complete.
    **TO CANCEL A CYCLE:
    Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
    DELAY START:
    The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
    The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
    TOP RACK ONLY:
    The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
    cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
    REFILL RINSE AGENT LED:
    The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
    illuminate when the Rinse Agent Dispenser is empty.
    Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
    closed even if the Dispenser is full, but will only remain lit for a few seconds.
    “F” CODE:
    An “F” in the display window indicates a filling fault.
    Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
    Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
    Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
    Good luck.
    macmarkus :)
    May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
    The hobart lxih is stuck in delime.
    To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
    DO NOT MIX DELIME ACID, RINSE AGENTS OR OTHER ACID WITH BLEACH PRODUCTS, OR HAZAEDOUS GASES WILL FORM.
    With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
    DO NOT LEAVE THE ACID IN ANY LONGER THAN RECOMMEDED.
    Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    Dishwasher doesnt drain on wash cycle,ok on rinse cycle
    Change the circuit board, timer/progrsmer.
    Take it out and clean contacts,
    Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
    Vitally
    May 03, 2009 | Maytag MDB7100AWB Dishwasher
    Kenmore Dishwasher 665.15895791 will not drain
    what sani-rinse does is turn the heater back on in the rinse cycle. You first should check the heater for voltage either at the start of the first cycle or do a ohms check.
    Please rate this !!!
    Jul 03, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
    THANKS
    Jun 30, 2007 | Maytag 24 in. MDB5601A Free-Standing...
    Maytag Dishwasher Logo
    264 people viewed this question
    Top Maytag Dishwashers Experts
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
