Question about Saws
How to attah table leg frame to table bottom panel?
    Problem Solver:
  • 11 Answers
Not quite sure what part(s) you're having problems with. But I'll tell you what I know...
There is a table top (a bunch of boards joined edge-to edge). Under this top is a skirt. The skirt is typically a box that doesn't need the table top for structural support - the legs are attached to the skirt (in the corners). Depending on how the skirt is designed, the legs may be removable (makes the skirt more complex).
Attaching the skirt to the table top can be done in many ways. The best way is to allow for expansion/contraction of the table top. The edge to edge combination of the table top makes for a larger expansion/contraction than the skirt. So the skirt should have a slot instead of a hole for a screw through to the table top.
If you just screw everything together, it will work. But if moisture and/or temperature changes, you may separate the table top, or joints in the skirt.
Posted on May 16, 2015
How do I remove the back cover from my flatscreen plasma TV?
Cover a table protective blanket.
Place TV face down on table.
Remove the stands legs( 2 screws each) then 4 large screws the legs attach to.
Or remove the wall mount brackets.
2 small black screws middle of the cover (above the component interface box).
Remove the component interface box, 5 small black screws , 2 on top, 3 on bottom.
6 black screws by the PC connection ports, (3 above, 3 below).
2 black screws on either side of the AC input plug.
12 screws around the perimeter.
Then the back should be able to be lifted straight up.
Aug 05, 2014 | Gateway GTW-P42M303 42 in. Plasma...
Table broken leg
You need some kind of screws/bolts to hold the broken pieces in place before you can apply glue. At the end of your video, you showed the bottom view of the legs. If you can drill some holes at good positions, you should be able to put bolt and nut to hold the legs in place. Then, you can use super glue to keep the surfaces smooth.
Apr 11, 2014 | Furniture
Just bought a Calligaris 'planet' table and it wobbles.
Check the legs and frame to see if it is out of square.
Sep 23, 2013 | Furniture
Help please
This is typically caused because the tabs surrounding the lcd screen have become loose.
One correction I've seen is to remove the frame and insert a pad (of the type found on the bottom of chair legs) between the frame and the lcd panel and resecure frame.
Jul 06, 2013 | Televison & Video
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
What can be done with a scoll saw, table legs?, what uses is the scroll saw for
Scroll saws use a small thin blade that runs up and down very fast. It is used to cut curved designs out of flat wood. Table legs are made on a lathe, it spins a square or round piece of wood to make legs, baseball bats.
Mar 01, 2011 | Garden
I need thd legs for the tv
Did you ever find the legs/table stand for this TV? I'm looking for the same.
Nov 29, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
I am trying to take the cover off the eddie bauer 3 in 1 to wash it. How do you get it apart from the buckle/latch that goes between their legs? It seems to be too big to go through that hole without...
Unbolt the seat from the floor of the truck... turn it upsidedown over a table or some such and the you will see the hog rings that hold the cover to the foam and bottom frame...
Jun 14, 2009 | Eddie Bauer Deluxe High Back Booster...
MEMORY QUESTION
This problem is caused by failure of the lithium memory battery #2032. To replace same remove top and bottom covers.Use a small pair of pliers or curved hemostats to hold the bottom of the speaker connection socket to the board as you unplug the connector. If it is not done you run the risk of loosening the socket from the circuit board. Carefully unplug the ribbon cables that connect the front panel to the main circuit board. You may leave the rest of the attached wires alone as they are long enough to permit service without removal. Remove two screws from each side of the front main frame and the single screw securing the main circuit board to the front panel board. Gently bow the front of the main frame sides inward to permit detachment of the front panel. On the bottom front of the front panel is a small flat battery soldered to the front circuit board on flat standoff legs. I do not know if this radio has fet components that could be damaged by static electricity but to be on the safe side I used a pencil soldering iron that was grounded to the frame to remove the legs and battery from the circuit board. Note the polarity of the battery before removal. The little standoff legs are spot welded to the battery. They may be either gently peeled off with small pliers or you may use a dremel tool with the cutting wheel to grind out the welds to the battery along the long axis of the legs. This last method does not deform the legs like the first method. Tin the insides of the legs where they were welded to the battery. Prepare the new CR 2032 lithium battery by sanding or scraping the surface where the legs will be reattached, then tin it also. With rosin core solder reattach the legs to the new battery. Try to avoid heating the battery more than necessary to get a good solder joint.The top side when completed should be the + side. Note the circuit board has the location for the + lead. Re-solder to board from the component side of the board. Reattach the front panel to the main frame with the ribbon cables on the correct side of the board. Carefully plug the ribbon cables back in, taking care they are fully seated in their sockets. Replace the bottom panel. Plug the speaker plug back into its socket, again grasping the socket gently with pliers to prevent loosening from board. Replace all screws and you should now be able to unplug the radio without lose of memory. I did leave the 13.6 volt dc supply connected the the radio during service as I was not sure if the total loss of memory voltage would damage the internal scanning program. Good Luck. Its not as complicated as it sounds if you have the right tools and some electronic experience.
Mar 29, 2008 | Uniden BC895XLT Base Scanner
Saws Logo
293 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
