Question about Bosch Washing Machines
How do i fix bosch maxx front loader when the power wont come on. Used it turned it off tried to turn back on no lights nothing. Yes checked power point, lead. think it might be an internal fuse???
The switch which is a dial or the internal wiring might have come loose or is it a common problem, maybehave something to do with the door and or latch. I have checked all apart from pulling anything apart just yet. thankx
    Genius:
  • Bosch Master
  • 1,585 Answers
No fuse try door inter lock
Posted on May 03, 2015
SolutionGuy
  • 331 Answers
SOURCE: Maytag Neptune front loader door latch won't release
rewpa, 98% chance the door latch has stuck in the locked position. Yes, follow Maytags suggestion to access the "rip cord" for the door latch... (this is the mechanical override for it) to get the door open. After it's open, run another load of wash and see if it happens again. If it does, it is the door latch assy. that's the problem. BTW, the door lock light is activated by a switch in the door latch assy. There's a "motor" in the assy... it's made of WAX! Yes, a "wax motor". Before the computer goes into spin, it sends 120V to this motor. The electricity heats the wax and it expands. As it expands, it pushes a plunger forward. This plunger trips both the door lock AND the switch. This sends the signal to the door light AND the computer saying "I'm locked! Go ahead and Spin!" When the cycle is complete, the computer drops the voltage to the wax motor. The wax cools off and contracts. This retracts the plunger... opening the door and shutting off the light. So... if this light stays on, the plunger is still extended and can be overridden using the rip cord. If this happens again, let me know and I'll step you through disassembly and replacement of the wax motor.
Posted on Aug 19, 2007
  • 79 Answers
SOURCE: door latch assembly for maytag neptune MAH5500BWW
The plastic cord is for opening the door if the door latch fails. It should connect to the door latch mechanism and the other end should be routed to the soap dispenser corner. There should be two holes for the cord to go into and out again. The idea is to remove the soap dispenser lid / bezel to get access to the pull cord if needed.
Hear the new Neptune bearing song at http://www.neptunehelp.com.
Posted on May 23, 2009
  • 1525 Answers
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Posted on Jul 21, 2009
beltronic205
  • 1466 Answers
SOURCE: How do I fit a new door latch to a Bosch Classic Maxx 1200
try utube video
Posted on Oct 03, 2009
SOURCE: How do I replace the door seal to a Bosch Front
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Posted on Feb 18, 2010
Can you remove drainage hose to clean on a Bosch maxx wae20261 6.5kg front loader? Washing machine is not draining properly. Thanks
The hose can be removed for inspection and cleaning but complete maintenance includes disassembly and inspection of the pump for removal of debris or that odd piece of clothing. Yes, it can happen!
Feb 11, 2017 | Bosch Washing Machines
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Interior lights flicker on just briefly when doors are opened then go out.Replaced door switches and light harness but still have problem..any ideas?
Any item not changed in the harness. like the light socket itself could be corroded, faulty, loose, or misaligned contact. same with any other electric component not changed by the harness or switch. If this is a digital unit then a board could be involved as well same problems with broken solder joint added.
Sep 10, 2015 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Remove internal door lining drivers side to get to internal power window winder
Usually two or three screws along bottom edge one behind all handles. Remove screws carefully pry panel loose away from door using caution not to damage the clips holding panel on might need a tool for this. I removed enough not to need tool. Have to pry all the way around panel, lift panel up off door by sliding it towards top of door. Disconnected all wire connections, to disconnect handle remove clip panel is off
Apr 03, 2015 | 2009 Hyundai i30 cw
No hot air from a/c vents on 2002 pontiac bonneville
On vacuum operated systems: The dial temp switch or vacuum motor is defective. You may have a vacuum leak or loose vacuum hose connection.
On electrically operated systems: The dial temp switch, electric door position motor, blend door position sensor, photo diode sunload sensor or the ATC control module is defective. Check for loose wires at connection points on the motor.
May 06, 2014 | 2002 Pontiac Bonneville
My GE profile Convention Microwave model JVM1790SK01 dial is loose and does not work. How can this be fixed?
see the information and use the common sense: God bless you
. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Sep 07, 2012 | Microwave Ovens
Air blend door
First check the connections at the blend dial if it is good there then take a look at the control assembly circuit board for broke or loose wires.
Jul 08, 2012 | 2004 Toyota Highlander
Bosch maxx clasic front loader Wkm41 the control panel has just died. what can I do to fix this?
I had the same issue this morning. I turned on the washing machine change a few settings, but didn't want these setting so i turned off and on again. When i turned it back on the panel was blank, but what had happen was the spin button was stuck in. Once i free the button the panel came back on.
Regards
Sep 10, 2010 | Bosch Washing Machines
Washing Machines Logo
85 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
