Question about Kenmore Vacuums
While using vacuum I get horrendous noise, suction is fine. I have the older bag type
  • Kenmore Master
  • 5,631 Answers
Actually, some vacuums has horrendous noise. Mine sounds like a spaceship blasting off. Now, if is is noisier then should be take suction tube of and listen it. Clean bag and check if it hasn't some dirt inside, zheck tube, if it hasn't some obstruction
If you can't find anything obvious and is on warranty., you should take it back where you bought it,
Maybe you could find CONTACT at www.kenmore.com
or call them to Contact 1-888-KENMORE
Posted on Apr 23, 2015
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
My dyson dc07 wont work using the hose i have
theres a o ring when u tilt the dyson from upright to 45 degree you will see it its either come off or the plastic housing that it sits in is not inline ..mark
Dec 12, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson upright vacuum cleaner makes horrendous noise
It might be a simple as changing the clutch belt and the drive belt and cleaning out the brush roll. You can get replacement belts here:
Dyson DC07 Belts
Dec 08, 2009 | Dyson DC07 All Floors Bagless Upright...
Loss of suction and very noisy
The most obvious and first fix would be to clean the filter. The noise is the tip-off. If your vacuum is noisier than usual the most common issue is a clogged filter, hose or bag. Check all of these. UNPLUGGED, use a straightened wire coat hanger to fish out any hoses and entry from the bag or bagless housing.
Foriegn obstruction is the main cause of noise coupled with loss of suction.
Dec 04, 2009 | Hoover Encore Supreme Energy U4293-930...
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Royal vacuum has no suction
If a vacuum has not suction then there has to be something plugged up in the port. You will probably have to remove the bottom. Either with a bag or bagless, find the suction port and usually it's plugged with all kinds of stuff. Sometimes if you have access to compressed air you could blow it out from where the bag hooks up or if bagless where it empties into the container. It's not that unusual for it to plug up. My parents have old old old carpet from I think the 70's, (The shag type that you can use a rake with) and there vacuum is always getting plugged up. Good luck.
Jul 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum doesn't ****
Assuming the unit (motor) runs ok and since it used, you may need to disassemble it and check the suction right at the motor. Sometimes there is a filter screen in front of it that can plug. The motor impeller could be partially obstructed or dirty, reducing the vacuum force. The bag should be the correct one for the unit or suction can be lost if it doesn't fit correctly.
Mar 28, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
No hose suction with replacement bag
The Bag must be blocking the port it connects to. Remove the bag and close it up. Test it again with no bag in it. If you have suction now, the bag is blocking the port. Maybe it is the wrong type, or installed wrong.
Feb 24, 2008 | Kenmore 28075 Bagged Canister Vacuum
Vacuums Logo
50 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
