Question about Radio Communications
My scanner wont come on I turn the switch on and nothing lights up I was wondering if it's dead.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Without model and make it's hard to say. First check the power and or batteries if it's a hand held model. I run into this issue with my Whistler scanner from time to time...I just remove the batteries and put them back in and it comes back.
Posted on May 03, 2015
Bike wont start, turn the key n everything lights up as normal, press the start button n just nothing
It could be the link from the starter button to the ignition coil. If you can check this for a current it should give an indication of the problem.
Jul 11, 2015 | 2005 Yamaha XVS 1100 Dragstar
Blazer wont start. when i turn the key to the on position there is nothing. no dash lights, nothing. i tried using a code scanner to see if that would help but appears that no power is being sent to that...
How's the battery ? Cables an connections ? Sounds like main power supply problem , do the headlamps light when you turn them on ? Dome lights light when you open a door ? Do you know how to test automotive electrical circuits ? Do you know what a wiring diagram is ? an how to read one ?
Electric Testing Techniques You Need to Know
Find a wiring diagram an test main B+ voltage supply to the ignition switch ,in an out at run an start positions !
If the key won't turn off with out pushing that hidden button you have a problem with power to the shift inter lock system . GM did have ignition switch problems on some year vehicle's !
Apr 18, 2017 | 1997 Chevrolet Blazer
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Car wont start
your missing a fuse or the ignition switch is not turning it on
Mar 31, 2012 | 2000 Mercury Grand Marquis
Turned of packard bell pc,,, now when i press startup button itt wont start.. no lights .. nothing .. have checked fuses and changed battery in pc,,, still nothing,,, can you help?
Check power cord, check power outlet, check powersupply, check the 120/240 volt switch in the back... set it to the correct position...
Apr 09, 2011 | Computers & Internet
My 2008 maxima is completely dead.. the intelligent key wasnt working so i switched the battery.. tried using the metal key to turn the ignition and that wont work.. its locked up and wont unlock.. nothing...
Have you checked the battery at all? you may have just left the lights on and flattened the battery. Try charging the system first, and check the underhood fuses. situated near the battery. Hope this helps.
Mar 10, 2011 | Nissan Maxima Cars & Trucks
Got full power to car check engine light is on car wont staRT PUT IN N AND NOTHING WHAT WILLSTART IT
IS IT TURNING OVER ,OR IS IT JUST LIKE THE BATTERY IS DEAD WHEN YOU TURN THE SWITCH, IF IT WILL NOT TURN OVER AT ALL IN P(PARK),OR N (NEUTRAL) THEN THE NEUTRAL SAFETY SWITCH IS MORE THAN LIKELY BAD .
Dec 05, 2009 | 1993 Toyota Camry V6
Radio Communications Logo
299 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
