Question about Garden
I bought a garden bench which iv not got yet can you help me
It was supposed to come from ground level last week but hasn't come
  • 3,960 Answers
You need to contact the customer service of the vendor you purchased this item from for assistance. Fixya does not perform these types of service.
Posted on Apr 23, 2015
Hi iv just bought a 206 gti 180 iv had it about two weeks now and it doesn't seem to be going up the revs as quick as it was. Car still goes fine it's just the revs on it are abit slower than it was. Car...
That whistle sort of noise, most likely, is a vacuum line disconnected from the engine causing loss of engine speed because it is no longer sealed and losing said vacuum. Check all the vacuum lines for connection and cracks/breaks.
Feb 26, 2018 | Cars & Trucks
I bought the black and decker 20Vmax*lithium sweeper. No.LSW221. Battery suppose to last a year didn't last 5Minutes. What is wrong?
has to be charged for at least 6 hous between uses
low speed is 20 minutes and high speed is 5 minutes
take it back for a warranty repalcement or repair
all of the 20 volt cleaners are in the same position as to operating time
May 15, 2017 | Garden
Perfect method to lessen weight for up-coming event therefore garments fit nicer?
To lessen your weight I suppose it will better if you decide to try some medicine like phen375
Jun 26, 2013 | Cars & Trucks
Where can I find assembly instructions for a Merry Garden Interchangeable picnic table and garden bench
I suggest that you contact the company directly by phone if you have their phone number. Also, try contacting the store that you bough it from. I'm sure they will help you with the assembly. I do not think that Merry Garden has a website.
Jul 29, 2012 | Merry Garden Interchangeable Picnic Table...
Our LT1000 will not start, not even turn over. Made a circle around the yard, cut it off to talk to someone. Then tried to start back and now it will not start. Even the next day still will not turn over....
remover the starter and bench test it with a battery charger or a battery to see if it works still. Maybe the starter solenoid is at fault only. Were the battery cable attaches to the starter bolt is positive and the starters housing is the ground. Connect the wires correctly to test this starter. The armature sounds like it is against the field casing keeping it from moving. It can be from a wormn armature shaft bushing if the starter seemed to operate just fine the time it started last
Jul 03, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hello, my LGTH2454 has been running fine. It sat for about an hour then I went to start it and the starter engaged on the flywheel but won't turn. I took the starter off and tested it. It seems to...
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up. Alex.
May 20, 2011 | Husqvarna 24HP 54" Yard Tractor ()
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
HP TX1410US laptop no display 4 long beeps
hi, same problem happened to my TX1410 tablet pc. there is not Display when i turn it on. it seems like i need to write the BIOS again. how did you solve the problem. or how did you updated firmware of your BIOS
Mar 21, 2009 | HP Pavilion tx1410us Tablet PC
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
