Question about Hayward Pool Products Hayward Aqua Rite Salt Chlorine Turbo Cell - 40,000 Gallons
I replace the Turbo Cell a month ago, the box is reading 3000 of salt however when testing the chlorine level is showing less than .5. What may be the problem?
    New Friend:
I did all that everything is set up correctly but still not generating any chlorine.
Posted on Apr 27, 2016
    Problem Solver:
  • 7 Answers
You have to instruct the panel which model of sell you have t5, T9, or t 15. Sticker is on the turno cell indicating the type. Press the diagnostic button until it displays the cell type and use the on/off/superchlorinate switxh to cycle through the cell model
Posted on May 02, 2015
    New Friend:
You Have to calibrate the new cell. Instructions are on line.
Salt Water System Model 8110 will not generate Chlorine
6000 gallon pool initial salt 129 lbs for count of 3000 ppm
Mar 05, 2017 | Intex Automatic Salt Water System for ...
My pool is cloudy and I added clarifier and it still won't clear. I checked the salt count and it's reading 1100 ppm. We have a 15 foot round 48 inch deep pool. I also shock the pool weekly...
1st... Your salt count should be at 3000 ppm... For your size pool, the start-up salt needed should be about 95 to 110 lbs..
2nd... Run your pump for 24 hrs without the chlorinator after you have reached the 3000 ppm to properly disolve the salt and use only "pool salt"
3rd... Set your pump at 12 hrs and your chlorinator at 10 to 11 of those hrs until you have reached the desired chlorine level.
4th.. After your pool water has cleared, within 2 to 3 days...clean your chlorinator electrolytic cell and adjust your time down to maintain the proper chlorine level..
Hope this helps and if it does, please rate and comment....
Good Luck!!!
Jul 31, 2011 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Hayward Pool Products Hayward Aqua Rite Salt Chlorine Turbo Cell - 40,000 Gallons Logo
255 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
