Question about Refrigerators
I just bought a KIC fridge n it doesn't turn on the light n it's not cold inside
  • Refrigerators Master
  • 5,323 Answers
CHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 27, 2015
  • 220 Answers
SOURCE: I have a 2 door
Pull it from against the wall, to let it breath. The condenser is usually in the back of the frige...It can also be a problem with the compressor or it's simply loosing freon. Make sure doors shut with a seal too. Try adjusting both thermostats too.
Posted on Apr 19, 2011
heatman101
  • 43501 Answers
SOURCE: KIC fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 28, 2011
  • 5370 Answers
SOURCE: Hi I have a very old KIC fridge freezer the
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Posted on Nov 01, 2011
  • 3 Answers
SOURCE: the fridge part is not cold
turn your control knob all the way off you will feel a click just after 0that is your reset. if that dont work then turn your ridge of at the mainand pull out the plug leave out for 15min then plug it back on.turn your control knob inside the fridge till you hear it clik on if it worksset your knob on 2 in winter 3 summer hope this helps
Posted on Nov 25, 2011
shawnhowell1
  • 9 Answers
SOURCE: my kic fridge not getting cold but light working
Check that your temp control is set half way. If still warm.you might have a blockage or a gas leak.
Posted on Jan 24, 2015
My kic fridge not getting cold but light working
Jan 24, 2015 | Refrigerators
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
I bought a new kic fridge with freezer about seven months ago. I have been using it ever since. However my electricity has recently been cut and I will be without electrity for the next 10 months. Can this...
It'll be fine. Leave the door ajar and clean it inside with bactericidal cleaner after you finish using it and before you start using it again.
May 09, 2012 | Freezers
KIC fridge not getting cold freezer ok , regassed 30 days ago
heatman101
Aug 27, 2011 | Refrigerators
I have a 2 door fridge, with the freezer at the bottom. My KIC fridge is 4 years old. My problem is that the freezer is cold, but the fridge is warm. I desperately need help, what cold this be ?
Apr 19, 2011 | Refrigerators
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
My KIC KTF255P-Aa Fridge is heating up
It's in defrost cycle, But it's getting to hot. has a limit on it think it's not working.
Sep 22, 2009 | Refrigerators
Fridge KIC 223L- FRIDGE NOT COLD ENOUGH
Gas; which also means that it has a leak that must be repaired and fixed. You cannot  buy refrigiation gas unless you have a license from the EPA.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
