Question about IBM Personal Wheelwriter 2
Turn typewriter on and it sounds like it is spinning the printwheel and all the lights come on and then nothing. It was just working 5 minutes ago.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
When the lights come on do they all stay on or flash? Are there any beeps? Need some more info.
Posted on May 24, 2016
3 Suggested Answers
chuckt528
  • 73 Answers
SOURCE: Typewriter won't return carriage
If cleaning and oiling the shaft doesn't work, the carrier motor is probably bad. Is there any noise when you hit return?
Posted on Jul 31, 2008
  • 3594 Answers
SOURCE: Wheelwriter 5 - the line
Probably a board or power supply. If you can get it to us i'm sure it can be repaired for under 150.00.
DickyO
Cleveland Business Machines
216-242-0027
Posted on Aug 19, 2011
I have an IBM Wheelwriter Typewriter II. A week ago the typewriter worked fine before a move from Texas to the St. Louis. When I reconnected the machine and turned it on nothing seems to happen. No...
Sounds like a power supply or a connector came loose in transit. If you know how to remove the case look for staples, paper clips etc. on or around the power supply and PC board.
DickyO
Apr 25, 2011 | Lexmark Wheelwriter 15 Series II...
Some formatting has been changed on our typewriter. When you try to type "f" you get nothing. Then when you hit another key after hitting "f", you get a strange symbol. We have already...
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. Check to make sure no pedals on the printwheel are bent.
Mar 03, 2011 | Brother EM-530 Typewriter
"Hammer" won't strike; printwheel won't turn; code key not workin
It sounds like the print solenoid cap is broken except for the printwheel not spinning. the caps are available for 20.00 including shipping and instructoins. The code not working may be a keyboard for a keyboard rebuild contact Geo. Beyers Co. @800-392-8085.
DickyO
216-241-0027
Jan 27, 2010 | Lexmark Wheelwriter 2000 Typewriter
The flywheel from my brother ml300 typwriter came off and i don't know how to put it back on
I assume by "flywheel", you are referring to the "printwheel" which is removable from the typewriter by unlatching the print hammer mechanism by pulling the black lever on the right side of the print hammer towards the front of the machine. To install the printwheel, drop the printwheel in its cartridge with the letters facing the paper, then push the print hammer assembly towards the paper to the latched position. Turn on machine, and the printwheel will spin and "home". If printwheel homing is not correct, repeat above procedure with slightly more pressure when latching the printwheel. (The printwheel must latch on to its drive spindle securely). Good Luck
Nov 25, 2009 | Brother ML-300 Typewriter
How do you reset printwheel?
The printwheel "homes" everytime the power is turned on. There are many causes of the printwheel losing it's homing during printing. Check that nothing is interfering with the printwheel spinning, like the correction tape, or ribbon. Type slowly and observe the movement ot the hammer to make sure the hammer returns to it's home position every time, if not the machine must be repaired (to retime the hammer cam) . You can removed and reinstall the printwheel to make sure it is seated on its' drive spindle securely. checke that the is no foreign material in the bottom of machine.
Nov 15, 2009 | Brother SX-4000 Typewriter
The keys I strike are not what appears on the paper. Could the print wheel need replaced?
My printwheel also does not print what is typed. took out and put back in now what? How do you reset?
Nov 10, 2009 | Brother SX-4000 Typewriter
When I turn on my wheelwriter 1000 it beeps 5 times then the #1 and #2 line space lights blink. The keys are frozen as if the typewriter is on off mode. I powered the machine down and unplugged it and...
First be sure the printwheel is installed properly, and look for debris in that area. Put some light oil on the silver shaft that the carrier slides on (WD40 is good).
DickyO
Jul 30, 2009 | IBM Office Equipment & Supplies
Smith Corona SL 460
Could be the printhead is at the right margin. But, if you hit the return key and nothing happins, it could be a bad board, power supply or transport motor. When you turn the machine on, does the printhead move all the way to the left, spin the printwheel and move to a set position?
Aug 21, 2008 | Smith Corona Wordsmith 100 Typewriter
Wheelwriter 10 Series II doesn't work
My repair book shows:
1 Make sure the printwheel in installed correctly. 2. make sure the ribbon and correction tape are installed correctly 3. turn the typewriter off wait 30 seconds then turn back on if the same thing happens install another printwheel. 4 turn the typewriter off wait 30 seconds then turn it back on if the same thing happens call for service.
Jan 17, 2008 | Lexmark Wheelwriter 10 Series II...
IBM Wheelwriter 15 Series II
Do any lights stay on or blink if so make sure the printwheel is in correctly, make sure the ribbon and correction tape cassetts are installed correctly, Turn the typewriter off wait 30 seconds then turn it back on if the same thing happens try another printwheel if the same thing happens take in in for repairs.
Oct 25, 2007 | Office Equipment & Supplies
IBM Personal Wheelwriter 2 Logo
347 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
