Question about Nakajima AE-740 Typewriter
Typing wrong characters. Shift doesn't change case. Have moved font size switch and is not on PS. Tried other wheels. Powered on/off. Any ideas?
  • 475 Answers
It sounds as if the print wheel may be jammed usually caused by a bent letter spoke. Remove the print wheel and check that it can turn also look inside the area that it sits in to see is there is something that is interfering with the wheel.
Posted on Apr 23, 2015
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
It stuck and make a buzz noise wrong character
Your ribbon may be stuck check it out, buy the way I bestow the sacred order of thee nomenclatcher Maximus for bestowing the information that is actually need in great detail, you would not beleive how non- descript some people are ie My typewriter doesn't work right? After a good public flogging I may get some information out of them, well done! Bret PS, It's rare but you may have popped a drive gear with power off, and unplugged try and move the print carriage (gently) back and forth it should move with about a Pound of resistance and not catch or sound crunchy, fluid motion will tell, good luck.
Mar 06, 2015 | Brother GX6750 Daisy wheel electronic...
Swintec 2640 Typing wrong characters
On the L. of the keyboard there is a slide switch for pitch it should be in 10, 12 or 15 not in PS. If it isn't in PS push down on it and slide it up and down a few times and leave it in 10 or 12.
DickyO
Mar 17, 2014 | Swintec 2640 Electronic Display Typewriter
How do I change font size on model AE-740
To change the font you must change the printwheel, you can change the spacing by sliding the switch on the L. side to 10, 12 or 15 DON'T USE PS IT WILL PRINT WRONG!
DickyO
Mar 24, 2011 | Nakajima AE-740 Typewriter
How to increase fornt size winxp ie 8- normally icon at bottom of web page ''100%,125%,150% + I have no icon.
Go to View , Text Size select the one that you want
or from the keyboard press Control - to make smaller or Control + to make larger
Apr 05, 2010 | Computers & Internet
How do i change the font size on a Wheelwriter
The font size is set by the printwheel, the printing on the P/W case will tell you the pitch 10, 12, 15 or PS. Change the wheel change the pitch.
DickyO
Dec 07, 2009 | Lexmark Wheelwriter 3000 Typewriter
Olympia supertype 330 types wrong characters
check the pitch setting to make sure that it matches the printwheel. It is the switch that is marked 10, 12, 15, PS. PS is proportional spacing and will only type correctly with a PS wheel. The number settings are for PICA ELITE and MICRO.. 10, 12 and 15. The numbers are characters per inch...so the larger the number, the smaller the character.. it is the opposite of FONT SIZE.
Feb 05, 2009 | Olympia Supertype 330 Typewriter
Need to change the font size
you would have to buy a new printwheel and change the pitch setting (which is a switch on the left side of the keyboard tha has 10, 12, 15, PS printed next to it) or just changing the pitch setting may get you the desired results. it won't hurt anything to change the settings, it just changes the spacing. The PS setting only works on a PS printwheel, any other kind will just print the wrong letters.
Nov 18, 2008 | Swintec 7040 Typewriter
Types wrong letters
It sounds like you have the 10,12,15,PS selector switch on PS with a 10, or 12 print wheel installed. Return to the left margin, move the switch to 10 and type.
Jun 25, 2008 | Swintec 7040 Typewriter
Nakajima AE-740 Typewriter Logo
106 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
