Question about Kenmore Refrigerators
I have a Kenmore 70323 side by side with bottom freezer. It keeps making a loud, high pitch buzzing sound. This stops on its own but will stop every time one off e doors are opened..
  • Kenmore Master
  • 5,323 Answers
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
I have a Kenmore 70323 side by side with bottom fr - 25661570-izj50bzy441rirqhwblyybfs-3-0.jpg
25661570-izj50bzy441rirqhwblyybfs-3-2.jpg I have a Kenmore 70323 side by side with bottom fr - 25661570-izj50bzy441rirqhwblyybfs-3-5.jpgt/uploads/images/25661570-izj50bzy441rirqhwblyybfs-3-5.jpg" alt="25661570I have a Kenmore 70323 side by side with bottom fr - 25661570-izj50bzy441rirqhwblyybfs-3-9.jpg"h_mi" />
I have a Kenmore 70323 side by side with bottom fr - 25661570-izj50bzy441rirqhwblyybfs-3-20.jpgmages/25661570-izj50bzy441rirqhwblyybfs-3-14.jpg" alt="25661570-izj50bzy441rirqhwblyybfs-3-14.jpg" class="h_mi" />
Posted on May 12, 2015
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 72 Answers
SOURCE: Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Posted on Jun 15, 2009
SOURCE: My Kenmore side-by-side refridgerator is making a loud humming noise.
Sounds like your compressor is not starting due to a faulty "starter PTC" a.k.a. start relay. Or a faulty compressor. The buzzing noise you hear is the compressor trying to start. When it's windings overheat, an internal cut-off switch "clicks" off until it cool down.
Then the cycle repeats.
Posted on Feb 27, 2010
livewire874
  • 618 Answers
SOURCE: freezer side of refrig makes a LOUD howling, high
Sounds like the evaporator fan (behind rear panel in freezer.
Posted on Nov 20, 2010
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Anyone ever experience a loud and high pitched buzzing type of sound coming from the 5 holes under the docking station??? Ive had it for a long time but rarely used it, worked like a champ until that
I notice that some of my cell phone wall chargers make a high pitched ringing sound, not that loud though. I think cheaper internal electrical components are the culprit. (Opinion)
Jan 30, 2014 | SDI iHome iH52B Remote Control for Apple...
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerators Logo
97 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
